Rivets for AAR Cuda Fiberglass hood #187823
01/08/09 02:29 PM
01/08/09 02:29 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
Are these anything special? Stainless or aluminum? funky shape? or what?
Anyone know where they can be bought?
Re: Rivets for AAR Fiberglass hood [Re: aarcuda] #187824
01/08/09 02:30 PM
01/08/09 02:30 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
Re: Rivets for AAR Fiberglass hood [Re: PAINT IT BLACK] #187825
01/08/09 02:38 PM
01/08/09 02:38 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
Here is a picture of the ones on my T/A. Nothing special....if I remember correctly they are stainless steel.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: Rivets for AAR Fiberglass hood [Re: Troy] #187826
01/08/09 02:59 PM
01/08/09 02:59 PM
Houston Texas
Houston Texas
Are the pins supposed to go in from side to side like that or front to back??
Re: Rivets for AAR Fiberglass hood [Re: PAINT IT BLACK] #187827
01/08/09 04:13 PM
01/08/09 04:13 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
Side to side for Fiberglass and Front to back for metal hoods.
Why the difference, im not sure. but thats the way it is
Re: Rivets for AAR Fiberglass hood [Re: PAINT IT BLACK] #187828
01/12/09 12:35 PM
01/12/09 12:35 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
Challengers go from side to side and Cudas go from front to rear. The reason (I believe) is the Challengers hood slopes far more that the Cudas. If you put the hood pin front to rear on a Challenger the pin only holds the hood down on one side of the pin.
If you look at the picture that I posted earlier.....that is a untouched T/A hood and you can see the scuff marks that is left from the pin digging into the base.
Re: Rivets for AAR Fiberglass hood [Re: Troy] #187829
01/12/09 01:53 PM
01/12/09 01:53 PM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
Is this for both fiberglass and steel hoods? Previous reply advised there was a difference between hood material.
Re: Rivets for AAR Fiberglass hood [Re: 6pkaar] #187830
01/12/09 02:19 PM
01/12/09 02:19 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
i got my aar in 86. at that time the car was not touched as you could easily see by the primer used to cover the rust and the worn off paint on the hood. the marks on the hood pin plates went side to side
maybe this is just one of those, "what did the guy on the line do" situations but I know on my car, my pins were side to side and thats the way I put them back on.
I even questioned it when I later saw some pins going front to back and that was when I was told that the hood material was the deciding factor.
Re: Rivets for AAR Fiberglass hood [Re: aarcuda] #187831
01/12/09 03:27 PM
01/12/09 03:27 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
That is the fun thing about Mopars......you can never say "never" or "always"!!
Here are two pictures that I just have. The orange AAR is a 17K survivor that is very original when it cam to the body. These pins went front to rear....
Re: Rivets for AAR Fiberglass hood [Re: Troy] #187832
01/12/09 03:29 PM
01/12/09 03:29 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
Here is a picture of that real low mile T/A that Berry Washington took and I saw it at Carlisle a few years ago.. These go Left to Right..
Re: Rivets for AAR Fiberglass hood [Re: Troy] #187833
01/12/09 05:18 PM
01/12/09 05:18 PM
MD
floyd Offline
floyd  Offline
MD
Oh-oh - A monkey in the wrench - how about diagonal?
Re: Rivets for AAR Fiberglass hood [Re: floyd] #187834
01/12/09 07:37 PM
01/12/09 07:37 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
That must be a 1971 thing...
Re: Rivets for AAR Fiberglass hood [Re: Troy] #187835
01/12/09 09:04 PM
01/12/09 09:04 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
They were all supposed to be installed front to rear on these cars originally.
As noted above, there are exceptions.
Re: Rivets for AAR Fiberglass hood [Re: Troy] #187836
01/12/09 09:21 PM
01/12/09 09:21 PM
East Coast, NJ
fig426 Offline
fig426  Offline
East Coast, NJ
Which way diagonally? From the outer corner facing towards the windshield? Or from the center of the grill facing towards the outside center of the fender? Is there an actual angle that can be laid out with a protractor or something?
Chris from New Jersey
Re: Rivets for AAR Fiberglass hood [Re: Troy] #187837
01/12/09 09:22 PM
01/12/09 09:22 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
on my cuda, I mounted the pins and routed the cables thru the way the manual states and u cannot place the pins sideways...the 23" cable won't do...mine was always forward and back anyways...and sideways don't look right
Re: Rivets for AAR Fiberglass hood [Re: AARCONV] #187838
03/03/09 07:41 PM
03/03/09 07:41 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
Back to the original question.
Where can you get the rivets or are they anything special?
Re: Rivets for AAR Fiberglass hood [Re: 6T6Cuda] #187839
03/04/09 12:08 AM
03/04/09 12:08 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Are they 5/16"?
How long?
Also since I am high jacking my rivit gun works great but cuts the post off to where it can be seen in the center od the rivit once it is done? Thoughts?
I used stainless pan head philips screws last time due to that, since the Rivits looked bad
Re: Rivets for AAR Fiberglass hood [Re: 340SIX] #187840
03/04/09 08:46 AM
03/04/09 08:46 AM
cataclysm80 Offline
cataclysm80  Offline
Tav
