Re: Oil Pan P/Up for 4.25" Stroke using 6 qt 70-71 Oil Pan?
[Re: Jeremiah]
#1878321
07/26/15 11:13 AM
07/26/15 11:13 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
The fitment on your windage tray is sloppy. Needs to be closer to the crank, but I still don't know if the bends in your pickup will clear. Try to install the pickup tube first and then slide the tray back into position.
[image][/image]
[Re: sgcuda]
#1878338
07/26/15 11:46 AM
07/26/15 11:46 AM
Posts: 4,313 Prospect, PA
BSB67
Prospect, PA
The fitment on your windage tray is sloppy. Needs to be closer to the crank, but I still don't know if the bends in your pickup will clear. Try to install the pickup tube first and then slide the tray back into position. I would actually try the non-stroker tray with the 4.25 arm and 2.20 rod journal. I bet it is close enough that you could easily clearance the tray at the rub points. I use the MP pick-up with the "six-pack" pan without issue. Be sure to also pre-check that the dip stick actually clears the windage tray.
[Re: Jeremiah]
#1878532
07/26/15 05:32 PM
07/26/15 05:32 PM
Posts: 43,172 Bend,OR USA
Cab_Burge
I've used the stock Mopar windage tray and enlarged the slots slightly on the sides on my old Duster motor, with the 4.25 and 4.300 stroke cranks with H beam BB Chevy type rods. I did use two cork/rubber oil pan gaskets(one on each side of thr tray) as well as using one of my home made crankshaft scrapers on the passenger side with half of a oil pan gasket glued to the block on the other side I used the stock 6 quart 1970/71 Mopar street hemi/440 6 pak oil pan also with the stock Mopar 3/8 pickup Summit now sells there 1970/71 6 quart hemi clone oil pan at a lot better price That car went 9.993 ET at 134.6MPH on Oregon 91 octane pump swill through the muffs with the air cleaner on in Woodburn in the summer I did find out I needed to keep the oil level above the add line cold to avoid having the oil pressure drop on the other end when I let off I checked the oil level with 6 quarts in that pan with the timing cover off, it was below the windage tray about a half to 3/4 inch with the motor semi level on a engine stand IHTHs
[Re: Jeremiah]
#1878581
07/26/15 07:07 PM
07/26/15 07:07 PM
Posts: 10,553 Rittman Ohio
fourgearsavoy
Rittman Ohio
I had clearance issues with the 440 source pickup so make sure it clears your rotating assembly before you bolt the pan on DAMHIK I ended up going with the stock type pick-up with the Milodon HEMI replacement pan. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
