Re: 440-1: leave ports in stock form?
[Re: 426keith]
#187812
01/08/09 03:47 PM
01/08/09 03:47 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
With minor bowl work i went 9.54 in my dart at 3000 lbs, 499 cubesb with a roller, 12.8/1 compression, and a dominater 9375. So you should see similar performance if you put just a bit of work into the bowls as suggested.
[Re: gregsdart]
#187813
01/08/09 08:15 PM
01/08/09 08:15 PM
Posts: 3,746 Riverside, California
Lil Demon
Similar - 511 ci, 3160lbs, box stock -1s, tunnel ram, twin 9375 doms - 9.38.
[Re: Lil Demon]
#187814
01/08/09 09:04 PM
01/08/09 09:04 PM
griff70440
how much E.T would you guys pick up with fully ported -1s?
mike
[Re: Ari440]
#187818
01/08/09 09:31 PM
01/08/09 09:31 PM
griff70440
2750 car 33.5-16-15 tire 456 gear 700 roller
[Re: 426keith]
#187820
01/10/09 09:57 AM
01/10/09 09:57 AM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
Thanks guys, I will disassemble them and give the a treat with the die grinder. CNC is out of my budget, but smoothing everything, especially the bowls I can do myself.
What is best protection for the valveseats when grinding the bowls except not to contact them with the grinder?
take your time by the seats!using a short extension with sanding cones will be more stable and wont chatter on you with a slower rpm.maybe put tape on the seat.
[Re: 426keith]
#187821
01/10/09 11:00 AM
01/10/09 11:00 AM
Posts: 3,395 Pa
Hot 340
Pa
Dont start the grinder till the cutter/drum is below the seats in the bowl. Make sure also to have the right cutter. And for Pete's sake dont let a $1000 head be the first thing you practice on.
