Page 4 of 5 1 2 3 4 5
Re: CNC'd ported vs hand ported heads: Discussion, long post [Re: BradH] #1876813
07/23/15 08:57 PM
07/23/15 08:57 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Originally Posted By BradH
Originally Posted By Smell Ya Later
... why does a cnc have to be one size fits all? Why are cnc porters only using one specific port program on one particular head?
It doesn't, and in some cases you'll find people who will offer different programs for the same casting, or different castings w/ application-specific programs to offer some options.
But those guys are working w/ either highly specialized racing applications and raw castings intended for custom porting... or deal in a part of the performance industry where there are far more people to offer a variety of heads to (SBC & SBF).
I am aware of this. But cnc porting in this thread is being addressed as a one size fits all non-custom option. And it doesnt have to be that way. 1. Custom hand port one port for specific application with flow characteristics you want 2.digitize 3. then put them in the heads with the machine. It doesnt mean you have to reuse that program for every head of that make and model
Re: CNC'd ported vs hand ported heads: Discussion, long post [Re: pittsburghracer] #1877137
07/24/15 11:14 AM
07/24/15 11:14 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Originally Posted By pittsburghracer
I just can't see paying twice to get it right. I could see if you got a GOOD cnc product but I've tested lots and they just aren't doing a very good job. They sure look pretty. A good Friend of mine challenged me to race my small tire car with his 20,000 dollar small block Ford with the pretty cnc heads and he can't even out-run my Edelbrock headed small block. LOL. He hasn't been quite so mouthy lately but I have a hard time keeping a straight face around him.
Get it "right?" So every head you have is ported to Prostock levels with welding, epoxy, sleeved pushrod and bolt holes and so forth?
I agree CNC is a production method, but let's not pretend that hand porting is all the same either. There's more than a few hacks and just plain average talents out there. CNC is selling for more than it's worth in many cases because clueless buyers are buying it. And that's fine, probably 75+% of Mopar guys don't need bleeding edge stuff because they're running bracket stuff.
My point was that the shop or porter could benefit from the machine doing much of the "dumb" metal removal. And frankly, there's a few porters who are under pricing their time for levels of performance that are simply beyond the reach of others. If people are paying 100% for 95% CNC and paying that same 100% for 100% from the hand porter, then that porter should be raising his prices. Because there is no substitute for winning, and if you need the "good stuff" to win, then that's all their is to it. Pay the man. S/F.....Ken M
Re: CNC'd ported vs hand ported heads: Discussion, long post [Re: pittsburghracer] #1877144
07/24/15 11:23 AM
07/24/15 11:23 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
CNC is the cats azz for duplication and reapeatibility.The program for the CNC is the magic.most programs are designed for maximum flow volume,minimum restrictions and optimum alignment.Each program is designed for the maximum effectivness for each particular application application.No one program is for "all" applications.
Re: CNC'd ported vs hand ported heads: Discussion, long post [Re: madscientist] #1877151
07/24/15 11:28 AM
07/24/15 11:28 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Originally Posted By madscientist
And here is the issue. You pay a 100% price for the CNC work and it's 95% (most time LESS than that). What Pittsburgh is seeing is exactly what I see.
Hell yes, if I could afford a CNC I would use it in a nanosecond. But I would FINISH the heads BEFORE they left me and not lie to the customer and tell him not to touch the ports.
I did read the interview with Larry Meaux (link is posted somewhere in the thread) and I have had 2 phone calls with him on surface finish. He said in the interview he has not done an A-B-A test on his finish. IIRC the interview is about 5 years old ands since then he has done SOME testing, but, IMHO, if he does not port at least 9 intakes to test, you really can't A-B-A them correctly.
I have tried to simulate (as close as possible) his finish and don't get the results he is seeing. Probably 5-6 reasons for that.
That's why you should find a head guy you can get along with, and do what he says.
CNC machines are nothing but computerized RE-production machines. As long as you understand a CNC finished head is still not finished, you'll be ok. You have a set of heads that have not reached their potential, but, by gar, they are CNC'd.
Continuing from the last post, this is my point. CNC, like much modern technology, is for freeing up men from the drudge of mindless repetitive labor. They're like illegals, without the drunk uninsured driving and knife fights in bars.
People run their gums about CNC stuff in their car because for most people it's not about the racing, it's about the jaw jacking.
Like I said, if a hand porter is doing 100% work for 100% cost, and the CNC guy is doing 90-95% work for 100% cost then the hand porter should be charging more, and he's a dope if he's not and making the fact that his stuff is better well known.
IMO, the "proper" place for CNC in racing (as opposed to bracket) is for doing billet heads and cutting full ports and chambers in unfinished castings (edelbrock pro-ports and the like). In addition to doing all the prep porting for the hand finishing.
And then there's stuff like TFS is doing with heads being designed for and finished on CNC, giving better performance at lower cost than doing the full Monte with aftermarket porting. S/F.....Ken M
Re: CNC'd ported vs hand ported heads: Discussion, long post [Re: B G Racing] #1877244
07/24/15 01:58 PM
07/24/15 01:58 PM
PA.
pittsburghracer Online work OP
"Little"John
pittsburghracer  Online Work OP
"Little"John
PA.
Sorry but I'm not getting this post. Duplication yes, but in EVERY case or head I've tested it has been BAD duplication. Flowbench shows it and the track times do too.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: CNC'd ported vs hand ported heads: Discussion, long post [Re: pittsburghracer] #1877254
07/24/15 02:14 PM
07/24/15 02:14 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
John, what do you mean by bad duplication? The machine wont fix a bad design, it has to be good before its copied. If its wrong, its the cylinder head specialist fault for cutting out a junk port. Nothing to do with the machine, its just copying the hack's work.
Re: CNC'd ported vs hand ported heads: Discussion, long post [Re: Hot 340] #1877261
07/24/15 02:20 PM
07/24/15 02:20 PM
PA.
"Little"John
"Little"John
PA.
I'm telling you that EVERY CNC'd head that I have ever tested has been pathetic and needed major work. Upper lifts on every head went turbulent and started backing up in flow numbers. Testing proves short-turn not capable of maintaining control and the air goes straight across the bowl shutting off air flow going across the top of the port. You can hear it happening. (think garbage disposal)
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: CNC'd ported vs hand ported heads: Discussion, long post [Re: pittsburghracer] #1877455
07/24/15 07:35 PM
07/24/15 07:35 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I understand what you're saying but I agree with smell, it's only a machine and only as good as the person programming it. Sounds like the CNC guys don't know what they're putting out, just machining a pretty product to sell, and making quick easy money. This happens in a lot of products. Someone does all the R&D then another guy somewhat closely copies the product with no money invested, pure profit, customer screwed because they listen to the hype.
Might add, if you had the CNC machine I'm sure you would not machine those bad areas that you're talking about. Do you think it's possible to duplicate you port work to the fine line, what I'm saying is the machine capable?
Re: CNC'd ported vs hand ported heads: Discussion, long post [Re: cudaman1969] #1877458
07/24/15 07:39 PM
07/24/15 07:39 PM
PA.
"Little"John
"Little"John
PA.
BINGO!!!!!!!!!!!!!! And I'm not saying there aren't GOOD cnc'd heads out there. I just haven't found them yet.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: CNC'd ported vs hand ported heads: Discussion, long post [Re: pittsburghracer] #1877495
07/24/15 08:37 PM
07/24/15 08:37 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
John all I can say is thank you again for this post. There will be some here who will bash you now for being so forthright. I have seen this in the past as well. When it happens just ignore them. Your points are valid. The performance of your cars speaks to your ability. I just wish there were more of these types of discussion on this forum. It is a learning experience for me and others I'm sure.
And to the other contributors on this thread. Thanks for your input. Jim
Re: CNC'd ported vs hand ported heads: Discussion, long post [Re: rt66jim] #1877582
07/24/15 11:27 PM
07/24/15 11:27 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
CNC porting has become a sales gimmick of sorts, and 99% of the heads on the market are fairly generic. As has been stated in this thread already, if the port being copied isn't great, the machine isn't going to make the head any better. That said, a cnc ported head will be more consistent from port to port than a hand ported head.
Alan Jones
Re: CNC'd ported vs hand ported heads: Discussion, long post [Re: pittsburghracer] #1877592
07/24/15 11:48 PM
07/24/15 11:48 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I can think of two CNC programs out there I know are good
W5 CNC program at Modern
Small block Eddie CNC at Modern
I would wager there are plenty more, but can verify as fact only these two, based on track results, which to me is all that matters.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: CNC'd ported vs hand ported heads: Discussion, long post [Re: B3422W5] #1877639
07/25/15 01:13 AM
07/25/15 01:13 AM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
That info Don has posted is the kind of info I would like to see others offer. Thanks Don for sharing.
Re: CNC'd ported vs hand ported heads: Discussion, long post [Re: pittsburghracer] #1877728
07/25/15 09:49 AM
07/25/15 09:49 AM
PA.
"Little"John
"Little"John
PA.
Here's a letter I received from a good Friend, Tim Bowman of Bowman performance. He doesn't post very often as he is usually busy teaching or in the shop building well thought out, high horsepower race engines. He was taught by one of the best so read this on his thoughts.
Been HAND porting heads 40+ years
Got to spend some time with probably one of the best hand porters out there, Joe Mondelo, RIP Joe I miss your input.
Proper hand porting has become a lost art.
Been flow testing for over 30 yrs of those 40 yrs
Its and ugly unrewarding job until you put them on and engine and make power.
I have never flow tested a cnc head Brand x or Mopar that ever flowed the claimed numbers AND didn't have major issues in the flow curve.
I'm with you on this one John, upper lift flow on a big head that should do it. Joke!
Garbage disposal? Sounds like someone took big crap in front of a big fan. That's what you got,crap
I promote cnc head sells, only with the plan than additional work needs to be done, and i charge on top of that.
cnc gets the rough work out of the way, John knows the time it takes to port n flow heads.
Repeatably JOKE! 40 cfm spread on the same head? That includes Hemi heads
Valve jobs as delivered, Lets not even go there. This is a big part of the final product
Also, on a cnc head, there are times where you can,t fix a problem they created without re- weld or sometimes epoxy
Cnc has a place in the market for those that do not have the skills to port heads, absolutely not offense intended to them.
But the product is not where it should be in this day and age.
Some of the cnc porting final finish looks like they cut lose a rabid beaver in there, come on Really?
Got so many cnc duplicate heads in here that are not even close to each other, wtf? is your equipment that wore out? Got any QC going on here ?
if your going to port heads for power/in all different applications better have a flow bench. Any novice can improve a cylinder head with in reason.
If you work with a flow bench, you need time to interpret what it is telling you also , it takes time and experience, I know John knows!
Lastly, there are a boat load of top self cnc heads being supplied out there, doing what there supposed to do, you just got to know who they are
and they are spoken of on Moparts.
My input John, feel free to post this, As for hand head porters, keep on grinding. Tim Bowman, Bowman Performance
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: CNC'd ported vs hand ported heads: Discussion, long post [Re: pittsburghracer] #1877733
07/25/15 10:09 AM
07/25/15 10:09 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
^ good stuff. Now all this thread needs to balance itself out is a good head porter who actually has a centroid and does more than copies cast ports and puts little shiny cutter marks in everything.
Re: CNC'd ported vs hand ported heads: Discussion, long post [Re: pittsburghracer] #1877741
07/25/15 10:25 AM
07/25/15 10:25 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
I think what some of the problem with CNC heads are most of the mass produced stuff is its more of a shine job than a real performance head.
No way would I hand port w9s or w8s but my CNC stuff all gets some hand finish work
Just valve job and blend can kill a good CNC port if done wrong.
I have updated some HAND PORT w9s and port to port before we recut them did not look bad but after you can see how far off hand port stuff can be.
Here is some pictures of bad a$$ CNC WORK. (Note valve job blend not done)
This is TRD cup head cut in house by Toyota.
Re: CNC'd ported vs hand ported heads: Discussion, long post [Re: W5DART66] #1877747
07/25/15 10:43 AM
07/25/15 10:43 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
Just like hand porting most of the time you get what you pay for.
$1000 CNC job most of the time will need some work to make good.
If you start out with bare Indy 360-whatever and hand port to max potential it would take 40 plus hours at $50.00 per hr. = $2000.00
The other deal with CNC castings have thin spots all the time to make money you can't junk lots of heads so most mass produced heads are backed off little vs what hand port master was.
My w9 program is on the "edge" gets little thin but it's not mass produced
I also have 3 intake programs for that same head to fit wide range of builds.
So you can cut smaller port and hand finish for application or cut the big one and add the weld that's needed with the customer knowing up front heads will have holes into water when done and need weld.
Re: CNC'd ported vs hand ported heads: Discussion, long post [Re: W5DART66] #1877750
07/25/15 10:46 AM
07/25/15 10:46 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
Some of my CNC cut heads with quality valve job.
Re: CNC'd ported vs hand ported heads: Discussion, long post [Re: pittsburghracer] #1877761
07/25/15 11:07 AM
07/25/15 11:07 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I really like the one line your friend said... which is
VERY TRUE... porting gets the bulk of the work out of the
way... then its the fine tuning... most people not realize
that it takes just a minor bit to change things... thats
when you either know things or not.. a bit too much and you
can screw it up also... believe me I know when I started
wave
Re: CNC'd ported vs hand ported heads: Discussion, long post [Re: MR_P_BODY] #1877890
07/25/15 03:33 PM
07/25/15 03:33 PM
SoCal
Brian Hafliger Offline
SoCal
I like the directional lines in the Toyota head...
Brian Hafliger
