15x7 Rallyes on an A-body Barracuda
#1874333
07/20/15 02:43 PM
07/20/15 02:43 PM
Posts: 3,288 Stroudsburg, PA
Erik
Stroudsburg, PA
Does anyone have the 15 x 7 4" BP rallyes on their Barracuda? Is there any problem with fit in the fenders?
Anyone have pics of them on their car?
Thanks!
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: 15x7 Rallyes on an A-body Barracuda
[Re: Erik]
#1874578
07/20/15 09:07 PM
07/20/15 09:07 PM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
I put them on a 69 Dart with BFG Radial T/As. I could barely get one finger thickness...about 1/2" ....between the tire and the inner fender lip....NOT rolled. The front was fine, I had it pretty low and raised it until the tire did not rub at full rt or left turn and it was an awesome stance. Don't know if this helps, I hope so.
Driving modern convenience in classic beauty
[Re: Erik]
#1874598
07/20/15 09:33 PM
07/20/15 09:33 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
I've cop rims that are the same 15x7 with 4.25" backspacing.
It all depends on the tires.
here's 225/60/15 tires front and rear. That can be close in the front. And alignment and past collision damage can change the fit.
225/60/15 in the rear with those rims is easy. I've run 235/60/15 in the rear also. And I'm sure a 245/60/15 will work too, but might rub a tiny bit on the leaf springs on aggressive cornering. A 1/16 spacer will take care of it.
[Re: Erik]
#1874985
07/21/15 11:44 AM
07/21/15 11:44 AM
Erik
Stroudsburg, PA
Thanks!
Been debating pulling off the 14" slots.
[Re: Erik]
#1877989
07/25/15 07:20 PM
07/25/15 07:20 PM
Posts: 1,018 Missouri
MOBodyman
Missouri
You can even go to 15x8 on the rear with no problem. Couldn't find a better pic right now but here's a pic of my old '68. It has 14x7s on the front, though. Dallas
2012 Rallye Redline Challenger, 1st new car! 2010 Ram 1500 4wd HEMI-hauler 2014 Dodge Dart-gas saver 4 projects and a bunch of parts cars, losing interest since buying the Challenger lol 1969 Dodge Coronet 500-'gonna fix 'er up someday!'
