15x7 Rallyes on an A-body Barracuda #1874333
07/20/15 02:43 PM
07/20/15 02:43 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Does anyone have the 15 x 7 4" BP rallyes on their Barracuda? Is there any problem with fit in the fenders?
Anyone have pics of them on their car?
Thanks!
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: 15x7 Rallyes on an A-body Barracuda [Re: Erik] #1874578
07/20/15 09:07 PM
07/20/15 09:07 PM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
I put them on a 69 Dart with BFG Radial T/As. I could barely get one finger thickness...about 1/2" ....between the tire and the inner fender lip....NOT rolled. The front was fine, I had it pretty low and raised it until the tire did not rub at full rt or left turn and it was an awesome stance.
Don't know if this helps, I hope so.
Driving modern convenience in classic beauty
Re: 15x7 Rallyes on an A-body Barracuda [Re: Erik] #1874598
07/20/15 09:33 PM
07/20/15 09:33 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I've cop rims that are the same 15x7 with 4.25" backspacing.
It all depends on the tires.
here's 225/60/15 tires front and rear. That can be close in the front. And alignment and past collision damage can change the fit.
225/60/15 in the rear with those rims is easy. I've run 235/60/15 in the rear also. And I'm sure a 245/60/15 will work too, but might rub a tiny bit on the leaf springs on aggressive cornering. A 1/16 spacer will take care of it.
Re: 15x7 Rallyes on an A-body Barracuda [Re: Erik] #1874604
07/20/15 09:39 PM
07/20/15 09:39 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Here's a 235/60/15 on the rear. The cop rims have the same exact specs as the 15x7 rallyes with the factory 15x7 4.25 backspacing.
Re: 15x7 Rallyes on an A-body Barracuda [Re: Erik] #1874985
07/21/15 11:44 AM
07/21/15 11:44 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Thanks!
Been debating pulling off the 14" slots.
Re: 15x7 Rallyes on an A-body Barracuda [Re: Erik] #1877989
07/25/15 07:20 PM
07/25/15 07:20 PM
Missouri
MOBodyman Offline
MOBodyman  Offline
Missouri
You can even go to 15x8 on the rear with no problem. Couldn't find a better pic right now but here's a pic of my old '68. It has 14x7s on the front, though.
Dallas
2012 Rallye Redline Challenger, 1st new car!
2010 Ram 1500 4wd HEMI-hauler
2014 Dodge Dart-gas saver
4 projects and a bunch of parts cars, losing interest since buying the Challenger lol
1969 Dodge Coronet 500-'gonna fix 'er up someday!'
