Rattle can epoxy? #187400
01/08/09 12:10 AM
01/08/09 12:10 AM
Great Lakes State
O
ONEBADBIRD Offline OP
O
Great Lakes State
I've never noticed epoxy primer in a rattle can. Have I just never looked hard enough for it or just not stumbled across it? It seems when most people do body work they usually always spray(hvlp) epoxy primer. It's supposed to be the best rust fighting layer on your car? So is there a reason if they don't rattle can it then why? Or have I just been in my cave to long. You would think it would come in handy for small jobs and such. Thanks, Jay
Re: Rattle can epoxy? [Re: ONEBADBIRD] #187401
01/08/09 12:13 AM
01/08/09 12:13 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Eastwood has it I 'think'
Re: Rattle can epoxy? [Re: OzHemi] #187402
01/08/09 12:22 AM
01/08/09 12:22 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Buy a quart of automotive grade epoxy primer + activator from a paint store and use a preval sprayer.
Re: Rattle can epoxy? [Re: ONEBADBIRD] #187403
01/08/09 12:26 AM
01/08/09 12:26 AM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
Quality epoxy primer is what they call a 2k product that has a resin and an activator. Most rattle can products are 1k due to the difficulty of mixing an activator inside the can. Also, once activated the epoxy will begin to set after a certain amount of time (pot life).
Re: Rattle can epoxy? [Re: 68CoronetRT] #187404
01/08/09 12:36 AM
01/08/09 12:36 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Re: Rattle can epoxy? [Re: OzHemi] #187405
01/08/09 12:51 AM
01/08/09 12:51 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Anybody use it, and?
Re: Rattle can epoxy? [Re: OzHemi] #187406
01/08/09 12:53 AM
01/08/09 12:53 AM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
It says the can has a pot life of 48 hours when you start to use it, as it mixes the two components right before the nozzle. For small parts, it would be fine.
Re: Rattle can epoxy? [Re: jcc] #187407
01/08/09 12:55 AM
01/08/09 12:55 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I have not used that one, but have used various other Eastwood products with excellent results each time.
Re: Rattle can epoxy? [Re: OzHemi] #187408
01/08/09 10:10 AM
01/08/09 10:10 AM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
2k primer in a spray can...
That is not epoxy primer!
Re: Rattle can epoxy? [Re: OzHemi] #187409
01/08/09 10:13 AM
01/08/09 10:13 AM
Great Lakes State
O
O
Great Lakes State
hhhhmmmm intriguing!!!! Thanks, Jay
Re: Rattle can epoxy? [Re: Aero426] #187410
01/08/09 11:23 AM
01/08/09 11:23 AM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Interesting product. If the paint and primer are mixed "right before the nozzle" then why the 48 hour pot life??? The fact it has a pot life makes me think you somehow activate the whole can at once. And 48 hours is a LONG pot life! Makes me wonder what the paint formulation really is.
Still...interesting. Makes me wonder if colors are right around the corner.
But, I think this would be targeted at those who don;t have a gun and just have a small project. In the long run you'd be better off just doing it old school (if you do any frequent paint work)
Re: Rattle can epoxy? [Re: Pacnorthcuda] #187411
01/08/09 11:35 AM
01/08/09 11:35 AM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
There has to be some residual material in the mixing area (before the nozzle) that will harden up on you.
I really don't expect anything in a rattle can to truly equal a traditional 2k paint product. I'm sure it's fine for small parts, cut throughs, etc. In that respect, it's a money saver.
Re: Rattle can epoxy? [Re: Aero426] #187412
01/08/09 12:23 PM
01/08/09 12:23 PM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
I haven't used them, but there is a "button" on the bottom of the can that when pushed breaks a seal on a chamber inside the can releasing part 2 of the paint into the part 1 of the paint. So the whole can is now activated, just as it would be in a conventional gun. I have never been sold on the idea that you can get as good of paint out of a spray bomb as you can from a gun. It's usually lots thinner so it can be pushed out of that small nozzle.
Re: Rattle can epoxy? [Re: 6pkaar] #187413
01/08/09 12:30 PM
01/08/09 12:30 PM
Thats what I was thinking--some method of activating the whole can. Makes sense.
This method makes even more sense for colors. Small projects. odd colors etc.
I wonder what the safety people think. Catalyzed paints are far more dangerous...that is IF they use the 'normal' isocyanate hardeners, which these may very well not!
Re: Rattle can epoxy? [Re: ONEBADBIRD] #187414
01/08/09 09:06 PM
01/08/09 09:06 PM
Martinez, California
Challenged Offline
Challenged  Offline
Hello, I have used the Max 2K primer in the , which was recommended by my local Autobody/Paint supplier, and am very happy with the results. It is great for small areas and save allot of time and work with mixing and cleaning equipment. As stated in a previous reply their is a button inserted into the cap. First you want to shake the can well to mix the base, remove the button and place it on the plunger located on the bottom of the can. Place the cap back on top and turn upside down on a solid surface.Punch the button after it is in place this will release the catalyst, all you do now is shake the can some more. It does have a limited shelf life once mixed but I have always used up what was in the can. This product really deserves a . Good luck on your project.....Ed
Re: Rattle can epoxy? [Re: Challenged] #187415
01/08/09 09:12 PM
01/08/09 09:12 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
SEM has High build, Epoxy and Etching primers in cans. They are around $13 a can.
