Average cost to update A/C?
#1873291
07/19/15 01:34 AM
07/19/15 01:34 AM
Posts: 16,831 Between Houston & Galveston TX
SattyNoCar
My '93 Dakota still has its original R12 system. The compressor kicks on when A/C or defrost is selected, but, its not cold. What's the average cost to convert over to 134? (assuming there is no major parts replacement). What all is involved? I checked around when I first got the truck and prices were all over the place. At the time I decided to wait until I knew the truck didn't have any (major) mechanical issues. The heat isn't as brutal as it was in my wagon, so, I've been living with it. Now that I know I want to keep the truck, I want to get the A/C working. Aside from pricing, any other sage words of advice? Thanks.
John
Re: Average cost to update A/C?
[Re: SattyNoCar]
#1873307
07/19/15 02:08 AM
07/19/15 02:08 AM
Posts: 954 garnett kansas
rhad
garnett kansas
i have a 92 dakota with the v6 magnum,when i changed mine over i just added the correct oil and fitting adapters,i also replaced the filter drier and the expansion valve and one bad return hose,drew a vacuum and charged it with 134a,no leaks and it blows cold,most people think you have to replace all the o rings,etc,i just put fresh o rings/seals where i had it apart,i DID NOT drain out the old oil from the compressor
my ladder of success is missing some rungs
[Re: SattyNoCar]
#1873604
07/19/15 04:32 PM
07/19/15 04:32 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
What's the average cost to convert over to 134? Why not just top off the R-12? Every system leaks down with time and the R-134 will leak faster.
[Re: John_Kunkel]
#1873611
07/19/15 04:40 PM
07/19/15 04:40 PM
SattyNoCar
What's the average cost to convert over to 134? Why not just top off the R-12? Every system leaks down with time and the R-134 will leak faster. Because I don't have the means to do it myself, and the few shops I found willing to do it, for the cost, I might as well convert.
John
[Re: SattyNoCar]
#1874599
07/20/15 09:33 PM
07/20/15 09:33 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I am with kenworth. I used to buy into the hype about you can't mix or swap them but I saw soooo many people doing it with no ill effect I say just go for it.
[Re: kenworth_goose]
#1875097
07/21/15 03:00 PM
07/21/15 03:00 PM
John_Kunkel
Rio Linda, CA
Go to the local auto parts store and buy a low side 134a fitting, screw it on and buy one can of 134 with a charge hose, turn the a/c on and charge it. Groan.
