Re: Does anyone rebuild the Strato Vent heater hose water valve?
[Re: mrrandyj]
#1870555
07/15/15 12:41 AM
07/15/15 12:41 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Call Jim Tucker. Don't email. Call. http://www.heatercontrolvalve.com/Ask him if he can rebuild yours. Some he says can't be rebuilt, but he does seem to have an inventory of originals for those, if you ask. He's not a good salesman - you have to pump him for information. I bought a valve from him 6 years ago and was very pleased.
[Re: mrrandyj]
#1870585
07/15/15 01:03 AM
07/15/15 01:03 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
Go on ebay and buy one for a Camaro and un-rivet or un-bolt (I forget which) the bracket. Then rivet to your old bracket.
I showed that to someone on a hemi sunroof strato vent car and works and looks well.
IIRC, it was around $20.
[Re: mrrandyj]
#1870977
07/15/15 05:05 PM
07/15/15 05:05 PM
autoxcuda
So Cal
I think you could just bolt your bracket to this one. Mustang Vavle You might be able to make this one function with your bracket. But it will look different. http://www.ebay.com/itm/66-67-68-69-70-7...28f&vxp=mtr If you search harder I think you could fine a brass valve section with right lever arm for under $50.
[Re: mrrandyj]
#1871003
07/15/15 06:07 PM
07/15/15 06:07 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Looks to me like the only part he needs is the valve, and that part unbolts, if the one he has with the rubber hose on it diaphragm still works that would be the one to repair?
[Re: kentj340]
#1871087
07/15/15 08:17 PM
07/15/15 08:17 PM
Posts: 1,544 CT
mrrandyj
CT
Call Jim Tucker. Don't email. Call. http://www.heatercontrolvalve.com/Ask him if he can rebuild yours. Some he says can't be rebuilt, but he does seem to have an inventory of originals for those, if you ask. He's not a good salesman - you have to pump him for information. I bought a valve from him 6 years ago and was very pleased. Thanks for the info! I called and talked to Jim, very knowledgeable guy! He said he can't rebuild this style of valve, and unfortunately he didn't have any NOS valves like it at the moment.
