Can't get 440 to prime oil #1868424
07/11/15 08:53 PM
07/11/15 08:53 PM
Mcgregor, Ia
493RT Offline OP
493RT  Offline OP
Mcgregor, Ia
Had the engine out and put in new rear main seal. Now that it is back in the car we wanted to prime it before starting it. Using the hex rod and drill going c.c.w.. Tried it for a couple minutes and nothing. Screwed off the filter and no oil....
Re: Can't get 440 to prime oil [Re: 493RT] #1868427
07/11/15 09:00 PM
07/11/15 09:00 PM
Q
Quicktree Offline
Quicktree  Offline
Q
revers the direction you are spinning it.
Re: Can't get 440 to prime oil [Re: 493RT] #1868432
07/11/15 09:10 PM
07/11/15 09:10 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
did you try filling the filter with oil?
Re: Can't get 440 to prime oil [Re: 493RT] #1868442
07/11/15 09:52 PM
07/11/15 09:52 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
leave the filter loose, put a bucket under it, then prime ccw. This allows the air trapped in the pump to escape. Once you get oil out to the filter you wont have any more issues.
Re: Can't get 440 to prime oil [Re: 493RT] #1868675
07/12/15 09:03 AM
07/12/15 09:03 AM
Australia
P
Project kickin A Offline
P
Australia
pack the pump with grease. works every time
Re: Can't get 440 to prime oil [Re: Quicktree] #1868703
07/12/15 11:30 AM
07/12/15 11:30 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
+1
Re: Can't get 440 to prime oil [Re: 493RT] #1868733
07/12/15 12:34 PM
07/12/15 12:34 PM
Minn
SportF Offline
SportF  Offline
Minn
I am pretty sure the distributor on big blocks goes counter clockwise as you look at it.
Re: Can't get 440 to prime oil [Re: SportF] #1868833
07/12/15 03:46 PM
07/12/15 03:46 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Loosen the filter, prime the pump until oil starts to flow out around the filter, tighten it back up and continue.
Re: Can't get 440 to prime oil [Re: GTX MATT] #1869298
07/13/15 11:06 AM
07/13/15 11:06 AM
Mcgregor, Ia
493RT Offline OP
493RT  Offline OP
Mcgregor, Ia
Thanks for the suggestions guys. I'm trying to relay this onto my son ,who is 90 miles away from me .
Re: Can't get 440 to prime oil [Re: 493RT] #1869335
07/13/15 11:59 AM
07/13/15 11:59 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Is this a internal or external pick up system...if its
a external system make sure there are no leaks
wave
Re: Can't get 440 to prime oil [Re: MR_P_BODY] #1869616
07/13/15 08:10 PM
07/13/15 08:10 PM
Mcgregor, Ia
493RT Offline OP
493RT  Offline OP
Mcgregor, Ia
Internal pump,stock
Re: Can't get 440 to prime oil [Re: 493RT] #1869624
07/13/15 08:21 PM
07/13/15 08:21 PM
Cab_Burge Online work
Cab_Burge  Online Work
did you remove the pump from the main cap? If so maybe it isn't seated properly on the cap now or the gasket is not seal up good enough to prevent air from sucking into the pump now work It worked before, it will work agian after you figure out what is causing this problem IHTHs up
Re: Can't get 440 to prime oil [Re: 493RT] #1869628
07/13/15 08:45 PM
07/13/15 08:45 PM
AndyF Offline
AndyF  Offline
Basic trouble shooting process. Verify that you have oil in the pan first. Verify that the drive rod is actually going into the oil pump. Verify that you are spinning the pump CCW. If it just spins then remove the oil filter and try it again. If you still don't get anything then remove the oil pump and open it up. Maybe the relief valve is stuck open, maybe the gasket was put on backwards. Maybe someone forgot to put the gears in it.
It isn't very complicated, just a few moving parts in the whole system.
Re: Can't get 440 to prime oil [Re: 493RT] #1869655
07/13/15 09:08 PM
07/13/15 09:08 PM
Internal pump,stock
440, and all Mopar BB , have external oil pumps. Mopar SB are internal shruggy
Re: Can't get 440 to prime oil [Re: 493RT] #1869663
07/13/15 09:13 PM
07/13/15 09:13 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
and don't forget to put the pipe plug in the ends of the rocker shafts, it can and will make a giant mess when the pump starts working blush
Re: Can't get 440 to prime oil [Re: 493RT] #1869712
07/13/15 09:53 PM
07/13/15 09:53 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Pick up in place? Likely can determine by removing pan drain plug and poke about or have a look with a flexible fiber optic type light.
Or camera.
Re: Can't get 440 to prime oil [Re: Sxrxrnr] #1869738
07/13/15 10:15 PM
07/13/15 10:15 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Um... guys. He has a small block. There are no big blocks with internal pumps. Distributor turns clockwise on a small block. whistling
[image][/image]
Re: Can't get 440 to prime oil [Re: 493RT] #1869768
07/13/15 10:26 PM
07/13/15 10:26 PM
sgcuda Offline
sgcuda  Offline
And if it is a big block, just unbolt the pump, remove the plate and fill it with white grease or petroleum jelly. Sounds like it just lost its prime.
[image][/image]
Re: Can't get 440 to prime oil [Re: MR_P_BODY] #1869822
07/13/15 11:39 PM
07/13/15 11:39 PM
Mcgregor, Ia
493RT Offline OP
493RT  Offline OP
Mcgregor, Ia
wave
Sorry guy's I meant internal pick up , external pump.
Re: Can't get 440 to prime oil [Re: 493RT] #1869859
07/14/15 12:18 AM
07/14/15 12:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
Is this a small block or big block... small block the dist is
in the back... big block its in the front.. the pumps turn the
opposite direction
wave
