Re: Can't get 440 to prime oil
[Re: 493RT]
#1868442
07/11/15 09:52 PM
07/11/15 09:52 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
leave the filter loose, put a bucket under it, then prime ccw. This allows the air trapped in the pump to escape. Once you get oil out to the filter you wont have any more issues.
[Re: SportF]
#1868833
07/12/15 03:46 PM
07/12/15 03:46 PM
Posts: 5,163 CT
GTX MATT
CT
Loosen the filter, prime the pump until oil starts to flow out around the filter, tighten it back up and continue.
[Re: 493RT]
#1869624
07/13/15 08:21 PM
07/13/15 08:21 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
did you remove the pump from the main cap? If so maybe it isn't seated properly on the cap now or the gasket is not seal up good enough to prevent air from sucking into the pump now It worked before, it will work agian after you figure out what is causing this problem IHTHs
[Re: 493RT]
#1869628
07/13/15 08:45 PM
07/13/15 08:45 PM
Posts: 31,050 Oregon
AndyF
Had the engine out and put in new rear main seal. Now that it is back in the car we wanted to prime it before starting it. Using the hex rod and drill going c.c.w.. Tried it for a couple minutes and nothing. Screwed off the filter and no oil.... Basic trouble shooting process. Verify that you have oil in the pan first. Verify that the drive rod is actually going into the oil pump. Verify that you are spinning the pump CCW. If it just spins then remove the oil filter and try it again. If you still don't get anything then remove the oil pump and open it up. Maybe the relief valve is stuck open, maybe the gasket was put on backwards. Maybe someone forgot to put the gears in it. It isn't very complicated, just a few moving parts in the whole system.
[Re: 493RT]
#1869712
07/13/15 09:53 PM
07/13/15 09:53 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Pick up in place? Likely can determine by removing pan drain plug and poke about or have a look with a flexible fiber optic type light.
Or camera.
[Re: Sxrxrnr]
#1869738
07/13/15 10:15 PM
07/13/15 10:15 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Um... guys. He has a small block. There are no big blocks with internal pumps. Distributor turns clockwise on a small block.
[image][/image]
[Re: 493RT]
#1869768
07/13/15 10:26 PM
07/13/15 10:26 PM
sgcuda
And if it is a big block, just unbolt the pump, remove the plate and fill it with white grease or petroleum jelly. Sounds like it just lost its prime.
[image][/image]
[Re: MR_P_BODY]
#1869822
07/13/15 11:39 PM
07/13/15 11:39 PM
Posts: 138 Mcgregor, Ia
493RT
Mcgregor, Ia
Is this a internal or external pick up system...if its a external system make sure there are no leaks Sorry guy's I meant internal pick up , external pump.
[Re: 493RT]
#1869859
07/14/15 12:18 AM
07/14/15 12:18 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Is this a internal or external pick up system...if its a external system make sure there are no leaks Sorry guy's I meant internal pick up , external pump. Is this a small block or big block... small block the dist is in the back... big block its in the front.. the pumps turn the opposite direction
