Wet-sanding a scratch repair. How fine a grit & sequence? #1868690
07/12/15 10:42 AM
07/12/15 10:42 AM
Toronto (YYZ) Ontario
YYZ Offline OP
YYZ  Offline OP
I need to repair a deep scratch on the family car which was done either with a ski pole (accident) or key (dbag).
Plan is to:
- apply a few coats of base color to the scratch
- wet sand the excess from the factory paint
- use clear to build up the scratch above the factory paint
- wet sand everything level
- polish
What grit(s) of wet sandpaper should I be using, and in what order? 1000/1500/2000?
I realize that the repair won't be completely invisible, but I'm loath to shell out $$$$ to refinish 2 doors and a fender on a two year old car.
Thanks in advance
Re: Wet-sanding a scratch repair. How fine a grit & sequence? [Re: YYZ] #1868880
07/12/15 05:07 PM
07/12/15 05:07 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
without seeing it it's difficult to guide you. Do be aware the clear coat on newer cars is very thin and does not like being sanded very much beer
Re: Wet-sanding a scratch repair. How fine a grit & sequence? [Re: YYZ] #1869233
07/13/15 07:13 AM
07/13/15 07:13 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Try a u tube search for automotive paint scratch repairs. I have seen several with some tips on how to deal with them.
Re: Wet-sanding a scratch repair. How fine a grit & sequence? [Re: YYZ] #1869388
07/13/15 01:51 PM
07/13/15 01:51 PM
crlush Offline
crlush  Offline
What color?
Re: Wet-sanding a scratch repair. How fine a grit & sequence? [Re: YYZ] #1871590
07/16/15 02:53 PM
07/16/15 02:53 PM
pa. usa
W
wayne o Offline
wayne o  Offline
W
pa. usa
Can you feel the scratch w/ your finger nail ? Do it in stages. Base, let dry, then 2 to 3 coats of clear. I would use 2000 grit wet sand paper. Make sure you use a block. You can also mix the base & clear together. Add alittle clear hardner.
