Page 1 of 3 1 2 3
HP limit for 440 Block, filled & alum caps #186593
01/07/09 10:31 AM
01/07/09 10:31 AM
Las Vegas NV
moparmanjames Offline OP
Las Vegas NV
Sorry for the old question, it's probably been covered before, but I'm lazy lol.
I'm hoping to make around 800 hp, will my block take it?
Re: HP limit for 440 Block, filled & alum caps [Re: moparmanjames] #186594
01/07/09 10:40 AM
01/07/09 10:40 AM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
I have been under the impression that 650-700 is pushing the limits of a stock block.
Re: HP limit for 440 Block, filled & alum caps [Re: camdog440] #186595
01/07/09 11:25 AM
01/07/09 11:25 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
The aluminum caps will help it a lot. Plus if you use aluminum rods it will help it even more. Whatever you can do to dampen the blow to the main webbing the better.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: HP limit for 440 Block, filled & alum caps [Re: Jacob Pitt] #186596
01/07/09 11:29 AM
01/07/09 11:29 AM
organ
maximum entropy Offline
organ
a girdle will help- alot.
Re: HP limit for 440 Block, filled & alum caps [Re: maximum entropy] #186597
01/07/09 11:59 AM
01/07/09 11:59 AM
Colorado,U.S.A
4404dart Offline
4404dart  Offline
Colorado,U.S.A
That BCR girdle and aluminum main caps looks like a great way to go. I've gone 9.30's @ 147, at 3300lbs, with a stock block and a main girdle. Freshening the engine right now, the block and all the parts are perfect.
Re: HP limit for 440 Block, filled & alum caps [Re: 4404dart] #186598
01/07/09 12:27 PM
01/07/09 12:27 PM
I have used a stock short filled block with program caps and steel rods with a stock 440 crank, and went 136mph in a 4005 lbs car. You do the math for horsepower. This will be the 4 year on the motor in 09, but it could also be the last?
There was also a little nitrous there to help me along....hehe!
Re: HP limit for 440 Block, filled & alum caps #186599
01/07/09 12:33 PM
01/07/09 12:33 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
JMO
They might last for a while under or at 700 hp. The main girdle, and other stuff will not keep them from splitting the cylinders. It seems this is 50% of the failures, the other is the main caps breaking. The after market stuff helps in this area, but nothing can be done about the cylinders...Im sorry filling the block doesn't help
Re: HP limit for 440 Block, filled & alum caps [Re: Bob_Coomer] #186600
01/07/09 12:44 PM
01/07/09 12:44 PM
Oh! I agree that they will not last forever but there is alot of guys who have made some big reliable power using a stock block. I estimate that I am making over 800 when I spray it. The day will come when the block has had enough.
Re: HP limit for 440 Block, filled & alum caps #186601
01/07/09 01:06 PM
01/07/09 01:06 PM
organ
organ
there's a guy at our track who's been making horsepower with a comma for many years with a stock block- fill and girdle. scary, but he has had zero problems. the mega blocks have not been so lucky. i think if you take pains, use the good parts and the best machine work and assembly, a good stock block can endure a lot. and there's that hot rod build up. what was that, about 1400? yikes.
Re: HP limit for 440 Block, filled & alum caps [Re: maximum entropy] #186602
01/07/09 01:11 PM
01/07/09 01:11 PM
Peoples republic of clackamas ...
atoetly Offline
atoetly  Offline
Mine lasted 4 seasons running mid 9's in a 3200lb dart with aluminum mains, aluminum rods and block filled.
Re: HP limit for 440 Block, filled & alum caps [Re: maximum entropy] #186603
01/07/09 01:43 PM
01/07/09 01:43 PM
mikemotorhead Offline
super street
super street
"the mega blocks have not been so lucky"
Maximum could you please elaborate???
Re: HP limit for 440 Block, filled & alum caps [Re: mikemotorhead] #186604
01/07/09 02:29 PM
01/07/09 02:29 PM
organ
organ
i've read about mega blocks having cap walk and bore thickness issues. i think it was the early blocks? there have been a couple of spectacular mega block failures in our area, but i think they were both the result of valve train failure. most engine failures i see are because of valve train failures, not block related, whether stock or aftermarket.
Re: HP limit for 440 Block, filled & alum caps [Re: maximum entropy] #186605
01/07/09 03:15 PM
01/07/09 03:15 PM
Las Vegas NV
Las Vegas NV
Thanks for the replies, I guess I might have to tone it down a bit for reliability, I wouldn't want to blow it up after teasing my chevy buddies
Re: HP limit for 440 Block, filled & alum caps [Re: moparmanjames] #186606
01/07/09 03:21 PM
01/07/09 03:21 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I am not a fan of "Girdles" and would never run one..but I have had more than one stock block with alum caps and rods, that made over 1,000hp on the spray. Actually never broken an alum capped block. Definitely not saying you won't break one, but I never have.
Monte
Re: HP limit for 440 Block, filled & alum caps [Re: Monte_Smith] #186607
01/07/09 03:33 PM
01/07/09 03:33 PM
Iowa
I
ironjay Offline
ironjay  Offline
I
Iowa
Just use a 400 block and make the HP that you want and last.
Re: HP limit for 440 Block, filled & alum caps [Re: ironjay] #186608
01/07/09 05:51 PM
01/07/09 05:51 PM
If you want it to live, I would say 600-650...
Re: HP limit for 440 Block, filled & alum caps [Re: moparmanjames] #186609
01/07/09 06:03 PM
01/07/09 06:03 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
get blown not blownup.
http://www.youtube.com/watch?v=rvYjTkyqrmk
Re: HP limit for 440 Block, filled & alum caps [Re: Monte_Smith] #186610
01/07/09 06:04 PM
01/07/09 06:04 PM
Las Vegas NV
Las Vegas NV
Monte
Thanks, I don't have aluminum rods, I guess I might be looking at that now though. I guess I should have asked before I bought my balanced rotating assembly.
Re: HP limit for 440 Block, filled & alum caps [Re: ironjay] #186611
01/07/09 06:05 PM
01/07/09 06:05 PM
Las Vegas NV
Las Vegas NV
I already bought the kit for a 440.
Re: HP limit for 440 Block, filled & alum caps [Re: blownzoom440] #186612
01/07/09 06:07 PM
01/07/09 06:07 PM
Las Vegas NV
Las Vegas NV
See, this I don't understand, I thought the stresses would be worse with a blower. I have been thinking about a procharger set up.
Page 1 of 3 1 2 3
