paint prep under vinyl top.... #1865495
07/06/15 11:04 PM
07/06/15 11:04 PM
Finally a HUSKER again
Moparnut426 Offline OP
I was just planning on a good coat or two of sealer after final wet sanding of the Cuda. Only paint the car where need bee to save materials.
Do I need to have it painted? or is the sealer a good enough material to cover with my top.
Re: paint prep under vinyl top.... [Re: Moparnut426] #1865556
07/07/15 12:06 AM
07/07/15 12:06 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I'm no painter, but I did have a discussion with a PPG paint rep and was told that epoxy primers and such are water resistant, but not 100% water proof over time and if in doubt paint it. If it were mine I would paint the car and then if you have a little paint left in the gun add enough reducer so you have enough to fog some paint on the roof. Anything is better than nothing.
Vinyl top cars have issues when they are left outside and get wet frequently. I have owned two vinyl top mopars from high desert areas and neither has any rust at all so it's all about exposure. Keep it inside and dry and you should never have any issues.
Re: paint prep under vinyl top.... [Re: Moparnut426] #1865565
07/07/15 12:14 AM
07/07/15 12:14 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I like to put some base coat on the roof, just get some coverage, then clear it like normal with the rest of the car.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: paint prep under vinyl top.... [Re: Silver70] #1865573
07/07/15 12:21 AM
07/07/15 12:21 AM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
The minimum.
Have a great day
Iowan
"obsolete is neat"
Re: paint prep under vinyl top.... [Re: Silver70] #1865575
07/07/15 12:25 AM
07/07/15 12:25 AM
Kirkland, Washington
Pacnorthcuda Offline
I did mine in s/s but yea, give it one coat of color then forget about it while you paint the car.
Verts and Vinyls are the EASIEST cars to paint!
Re: paint prep under vinyl top.... [Re: Moparnut426] #1865742
07/07/15 10:33 AM
07/07/15 10:33 AM
thanks guys
Re: paint prep under vinyl top.... [Re: Moparnut426] #1865940
07/07/15 04:35 PM
07/07/15 04:35 PM
South Dakota
hotairballoonpilot Offline
South Dakota
Put sealer on it,1 coat of base then 2 clear and then you have enough to sand it for the glue and not to thin were you have moisture issues or anything g like that. Way I did dad's cuda and that 68 charger and the 70 swinger I did 10 years ago.
Corey
Contact Me about AMD Prices
Re: paint prep under vinyl top.... [Re: Moparnut426] #1866565
07/08/15 02:06 PM
07/08/15 02:06 PM
thanks Corey
