70 ta challenger wheel weights #1864446
07/05/15 06:42 PM
07/05/15 06:42 PM
Upper Michigan
sixpacchallenger Offline OP
Upper Michigan
What wheel weights are correct for a 70 ta challenger?LH with the diamond around the letters? thanks John
Re: 70 ta challenger wheel weights [Re: sixpacchallenger] #1864979
07/06/15 12:01 PM
07/06/15 12:01 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
yes, that's correct
Re: 70 ta challenger wheel weights [Re: sixpacchallenger] #1864980
07/06/15 12:02 PM
07/06/15 12:02 PM
DELAWARE
DELAWARE
id insert a pic I have on my computer but can only find a way how to put an image on from a webpage
can anyone help with that?
Re: 70 ta challenger wheel weights [Re: sixpacchallenger] #1865004
07/06/15 12:33 PM
07/06/15 12:33 PM
DELAWARE
DELAWARE
pic
wheel weight (Large).png (193 downloads)
Re: 70 ta challenger wheel weights [Re: TONY_DAGOSTINO] #1865005
07/06/15 12:36 PM
07/06/15 12:36 PM
Upper Michigan
Upper Michigan
thanks for the info Tony. Same weights on my original A12 RR.
Re: 70 ta challenger wheel weights [Re: sixpacchallenger] #1865356
07/06/15 07:34 PM
07/06/15 07:34 PM
Wahoo Nebr
vette1986 Offline
vette1986  Offline
Wahoo Nebr
anyone repop those?
1969.5 A12 Bee EV2
1971 Charger RT
1973 Duster tubbed 500 low deck 10.90 monster
3 440 polara vert projects
Re: 70 ta challenger wheel weights [Re: sixpacchallenger] #1865641
07/07/15 02:37 AM
07/07/15 02:37 AM
resq302
resq302
I wish !
Re: 70 ta challenger wheel weights [Re: sixpacchallenger] #1866038
07/07/15 07:39 PM
07/07/15 07:39 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
That would be cool if someone did.A nice little touch.
Re: 70 ta challenger wheel weights [Re: 5carguy] #1867799
07/10/15 04:57 PM
07/10/15 04:57 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
It would be a simple thing to make! But may be cost prohibitive for someone to do so
I have a mold maker that makes me lots of custom lead molds.
I cast lots of lead. Sitting on 3000#'s of as I type.
3 things would be I would needed.
Minimum run is 10 molds made per run. Do to drawing them up and set up time to run.
So would be into that at $1000.00-$1200.00 Plus for each size. Selling enough weights just to brake even would never happen.
I mainly get Brass customs made vs Aluminum
I normally run 2 molds at same time with the bottom pour pot. the other 8 I would be stuck with as selling them would defeat me doing them as others would just under cut or be a completing with me.
So would need to be one run one size weight.
Be costly to have 10 molds for 1 oz. 10 for 1/2 oz etc.
And the other would be a source to clips.
Yes I have lots of clips when I smelt down old weights, into ingots. Maybe a new weight maker would out source me some clips? But again would need to buy in bulk
But the mold would need to be made for the shape of clip used if that makes sense.
And the main thing is is this copy righted part? No one would want to get sued
