Re: 16 foot open trailer and A body???? [Re: Cab_Burge] #1864261
07/05/15 01:37 PM
07/05/15 01:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
DOn.. forget about centering the car over the trailer axles..
thats BS... with the trailer and truck LEVEL.. then put the
car on the trailer...take it to get the total trailer/car weight
and based on that number move the car fore and aft to get 10%
to 15% MAX on the tongue... you might need lift bars.. when you
put the bars on you bring the back of the truck and the front of
the trailer back up to LEVEL.... in MOST cases you will find that
the top of the ball will be at 19" to keep the trailer level.. once
you find that load balance point.. mount a set of stops for the front
wheels... I wont tell you I know what I'm saying.. but years ago I did
trailer design for U-Haul
wave
Re: 16 foot open trailer and A body???? [Re: B3422W5] #1864638
07/05/15 10:40 PM
07/05/15 10:40 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
A 16' open beavertail has been my Duster's trailer for decades. Overhangs the rear a bit with the weight basically as Mr P says. Ft tires about 6" or so aft of the ft edge of the deck, where I bolted some wheel chocks.
I've had my Road Runner & my '63 & '64 Savoy wagons on it, but found the limit with a long-bed '68 Chevy pickup...rear wheels were close to the rear edge of the deck, barely fit.
I mounted a PU-truck toolbox forward of the ramps, a floor-jack tray between the box & the ramps, and an electric winch inside the box (hole in rear wall for cable).
Tows fine, and the box is also handy for some of the race stuff, tie-downs, etc.
An antenna & antenna-ball I mounted near the coupler makes it easy to line up for backing the truck up to it. Reference decal centered in back window of the canopy/bedcap.
Re: 16 foot open trailer and A body???? [Re: B3422W5] #1864675
07/05/15 10:54 PM
07/05/15 10:54 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I think a Duster/Demon has a 110 in. wheel base. My D50 also has a 110 in. wheel base and when I put it on the trailer so my tow vehicle (Dakota) is level the front wheels are a little more than 5 ft. from the head rail. I just measured my trailer and it is 15 ft. flat with a 3 ft. dove tail. My back tires are just barely on the flat part of the trailer. Best towing trailer I have ever owned.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: 16 foot open trailer and A body???? [Re: B3422W5] #1864679
07/05/15 10:58 PM
07/05/15 10:58 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
A Duster has 108" wheelbase. Our Challenger has 110" and it also fits on a 16' trailer.
Re: 16 foot open trailer and A body???? [Re: B3422W5] #1868735
07/12/15 12:36 PM
07/12/15 12:36 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
My B body on a 16'
Re: 16 foot open trailer and A body???? [Re: RV2] #1868736
07/12/15 12:38 PM
07/12/15 12:38 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Back
Re: 16 foot open trailer and A body???? [Re: B3422W5] #1868761
07/12/15 01:30 PM
07/12/15 01:30 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
I have to figure out a shorter strap deal for the front. The eyelets are cose to the tie down point.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 16 foot open trailer and A body???? [Re: Cab_Burge] #1868778
07/12/15 02:13 PM
07/12/15 02:13 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Originally Posted By Cab_Burge
The Duster and other short wheel base A bodys are 108 inches which is 12 ft. ,correct?
NO. The Duster was 108" (9'), the shortest A body was 106" (8'10").
I had a 13'10" trailer that I hauled A and B bodies with.
When I built it, I mounted the axles so I could load a B body all the way to the front of the runners and a A body about 6" further back. The back of the car hung past the end of the runners a bit, this bothers some, I don't know why it matters as it doesn't effect towing.
I now have a trailer with 16' runners and a tool box (2'deep-2.5'long-5'wide) in front. I wish I had my old trailer back, it weighted less, pulled better and took less room to store.
Re: 16 foot open trailer and A body???? [Re: B5 Bee] #1868887
07/12/15 05:23 PM
07/12/15 05:23 PM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
A-bodies on a 16 foot trailer are no problem at all.
I've carried stuff a lot larger on my 16 foot trailer. laugh2
It handled fine, speed of about 60-65.
