Going from 7 PSI to 16 PSI radiator cap. Problem? #186439
01/07/09 01:22 AM
01/07/09 01:22 AM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
I just got a new radiator cap that has a built in temp guage and i noticed it is 16 PSI rated cap. The one i have now is the stock 7 PSI cap. Any worries over this much change, or does it not matter?
Stu
Re: Going from 7 PSI to 16 PSI radiator cap. Problem? [Re: MidPenMopar] #186440
01/07/09 01:33 AM
01/07/09 01:33 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
Stu, the factory correct cap is 16lbs. Are you using a stock radiator or something fancy? I have an aluminum unit and use a 16lb not sure what a 7lb cap would be used for?
Re: Going from 7 PSI to 16 PSI radiator cap. Problem? [Re: SCATPK] #186441
01/07/09 01:40 AM
01/07/09 01:40 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Wouldn't that be used if you have a recovery system like new cars?
Ride eternal, shiny and chrome
Re: Going from 7 PSI to 16 PSI radiator cap. Problem? [Re: DirectSubjection] #186442
01/07/09 01:45 AM
01/07/09 01:45 AM
Yes i set up a recovery system. I got the radiator cap from the shop that recored my existing radiator. He said that 7 PSI cap was correct for this appication. Guess he was wrong?
Re: Going from 7 PSI to 16 PSI radiator cap. Problem? [Re: MidPenMopar] #186443
01/07/09 01:52 AM
01/07/09 01:52 AM
Here
Here
But if you have added a modern recovery system, the type that sucks it back in from the bottom of the recovery tank rather than just being a catch can - wouldn't the 7 be the right one?
Re: Going from 7 PSI to 16 PSI radiator cap. Problem? [Re: DirectSubjection] #186444
01/07/09 02:04 AM
01/07/09 02:04 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Pure water boils at 212 deg F at sea level..
Pure water pressurised to 7 psi boils at around 235-240
Pressurised to 16 psi iy boils at 260ish...
I think use of 7 psi caps ended around 1960..Turns out 64 was the last year...
I know your car should have a 16 psi cap..
Re: Going from 7 PSI to 16 PSI radiator cap. Problem? [Re: MidPenMopar] #186445
01/07/09 02:09 AM
01/07/09 02:09 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
You sure it's not a 710 cap Stu?
Re: Going from 7 PSI to 16 PSI radiator cap. Problem? [Re: OzHemi] #186446
01/07/09 02:12 AM
01/07/09 02:12 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The famous 710 cap...
Re: Going from 7 PSI to 16 PSI radiator cap. Problem? [Re: OzHemi] #186447
01/07/09 02:12 AM
01/07/09 02:12 AM
All the recovery(& non recovery) caps that I have seen(& used) are 15-16 lbs. I have never seen a 7 lb one.
Re: Going from 7 PSI to 16 PSI radiator cap. Problem? [Re: 1_WILD_RT] #186448
01/07/09 02:14 AM
01/07/09 02:14 AM
Here
Here
OK - since your car was 16 originally it seems 16 is correct.
here's a quote from a Ford truck board I just found. They were roiginally 7lb caps.
"I've been through the radiator cap thing too. Seems everyone is correct in their answers. Here's what I learned: the 7 lb. cap is correct and neccessary if you are using your original factory as issued 50's or 60's radiator as stated by cdherman. The facts about cap {system} PSI allowing higher boiling points as stated by 44dwarf are true also. What we don't know is whether your radiator is original or a replacement model made in the last 20 years or so. The way I had it explained to me by a long time friend in the radiator biz was that any radiator made nowadays has a much stronger core and tanks and can stand the 13-16 psi caps that are used now which will benefit the overall performance of your trucks cooling system. I have had a 16 lb cap on my '66 since 1982 when I replaced the original radiator with no problems at all. I am assuming you don't have the original radiator in your truck so the higher psi cap should be fine with all else in proper working on your trucks cooling system."
Re: Going from 7 PSI to 16 PSI radiator cap. Problem? [Re: DirectSubjection] #186449
01/07/09 02:19 AM
01/07/09 02:19 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Re: Going from 7 PSI to 16 PSI radiator cap. Problem? [Re: OzHemi] #186450
01/07/09 08:51 AM
01/07/09 08:51 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
im another guy that never heard of using a 7lb cap.... 16 lbs sounds like the right one to me.
Re: Going from 7 PSI to 16 PSI radiator cap. Problem? [Re: aarcuda] #186451
01/07/09 09:21 AM
01/07/09 09:21 AM
I now remember that the shop that recored my radiator gave me a 7 PSI as they said they felt an original 40 year old unit was safer using a less pressured system. I.E. not going to leak or fail as easy. Maybe just covering their butts on this issue?
Re: Going from 7 PSI to 16 PSI radiator cap. Problem? [Re: MidPenMopar] #186452
01/07/09 09:56 AM
01/07/09 09:56 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i use a 7lb cap on my 65 coronet 440 6-pak moder. works fine with a recovery system. mopar had some 70's and 80's cars that used a 7lb cap. if your cooling system is marginal and the engine runs hot use a 13lb or 16lb cap. if your system stays cool then don't be afraid of a 7lb system. a higher altitude would probably want a 13lb or 16lb system.
Re: Going from 7 PSI to 16 PSI radiator cap. Problem? [Re: MidPenMopar] #186453
01/07/09 09:56 AM
01/07/09 09:56 AM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
The problem with a 7 lb cap is engine temp when you shut it off.You know (or should) that the engine temp rises after shut off.If the cooling system is filled to the point it has little or no room for expansion,you know where it goes,out the overflow.A 7 lb cap won't hold the pressure.
Re: Going from 7 PSI to 16 PSI radiator cap. Problem? [Re: I go fast] #186454
01/07/09 10:58 AM
01/07/09 10:58 AM
Thanks for the advice guys i am switching to the 16 PSI cap and will see if anything changes for better or worse?
Re: Going from 7 PSI to 16 PSI radiator cap. Problem? [Re: MidPenMopar] #186455
01/07/09 04:24 PM
01/07/09 04:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I've had a couple of radiator shops recommend the 7 psi cap when repairing "iffy" cores/tanks.
Re: Going from 7 PSI to 16 PSI radiator cap. Problem? [Re: MidPenMopar] #186456
01/07/09 08:09 PM
01/07/09 08:09 PM
Here's the cap. Now why can't they make it so it sits straight on??
Re: Going from 7 PSI to 16 PSI radiator cap. Problem? [Re: MidPenMopar] #186457
01/07/09 11:44 PM
01/07/09 11:44 PM
Here
Here
Re: Going from 7 PSI to 16 PSI radiator cap. Problem? [Re: DirectSubjection] #186458
01/07/09 11:54 PM
01/07/09 11:54 PM
Yeah yeah, i know....
