Going from 7 PSI to 16 PSI radiator cap. Problem?
#186439
01/07/09 01:22 AM
01/07/09 01:22 AM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
I just got a new radiator cap that has a built in temp guage and i noticed it is 16 PSI rated cap. The one i have now is the stock 7 PSI cap. Any worries over this much change, or does it not matter? Thanks Stu
Re: Going from 7 PSI to 16 PSI radiator cap. Problem?
[Re: DirectSubjection]
#186442
01/07/09 01:45 AM
01/07/09 01:45 AM
MidPenMopar
I have an aluminum unit and use a 16lb not sure what a 7lb cap would be used for?
Wouldn't that be used if you have a recovery system like new cars?
Yes i set up a recovery system. I got the radiator cap from the shop that recored my existing radiator. He said that 7 PSI cap was correct for this appication. Guess he was wrong?
[Re: MidPenMopar]
#186443
01/07/09 01:52 AM
01/07/09 01:52 AM
Posts: 70,126 Here
DirectSubjection
Tacohead. The First and Only
Here
But if you have added a modern recovery system, the type that sucks it back in from the bottom of the recovery tank rather than just being a catch can - wouldn't the 7 be the right one?
Ride eternal, shiny and chrome
[Re: OzHemi]
#186447
01/07/09 02:12 AM
01/07/09 02:12 AM
RapidRobert
All the recovery(& non recovery) caps that I have seen(& used) are 15-16 lbs. I have never seen a 7 lb one.
