What would you do... ??
#1863253
07/04/15 01:45 AM
07/04/15 01:45 AM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
The trans broke on a 1st to 2nd shift today.. obviously it doesnt like this power level.. I have reverse, but no forward gears.. ![bawling bawling](/ubbthreads/images/graemlins/custom/bawling.gif) So exploring my options, I can pick up a built Glide with all the needed parts for somewhere around $5k... Or I can pick up a used ProFlite with all the bells n whistles and bolt it in and go, for half that amount... Keeping in mind that California is experiencing a drought and its illegal to water my money tree, I have to be carefull which way I go and there is other things on my "must get" list.. So what would you do? 3000 lbs A-body with 1000hp at the crank.. 456 gears... 34 tall tire..
Re: What would you do... ??
[Re: Jeepmon]
#1863255
07/04/15 01:46 AM
07/04/15 01:46 AM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
Listen to the guy on the phone....
[Re: Jeepmon]
#1863270
07/04/15 02:09 AM
07/04/15 02:09 AM
Posts: 43,315 Bend,OR USA
Cab_Burge
Proflyte in a California heartbeat ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Ask Dave which gear ratios he would want you to run and see how they work ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) 2nd reading, I don't think I would buy a use any brand racing trans unless I drove it from when it was new ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: Jeepmon]
#1864302
07/05/15 02:39 PM
07/05/15 02:39 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
What kind of racing you want to do? I don't think there is one universal answer.
"Just a Bracket car dressed up like a streetcar"
[Re: Jeepmon]
#1864331
07/05/15 03:28 PM
07/05/15 03:28 PM
Al_Alguire
Las Vegas
I think some need to keep in mind the power plant and steam it makes. It is not your average 10 second Mopar deal, just saying and feel free to flame away
[Re: Jeepmon]
#1864335
07/05/15 03:36 PM
07/05/15 03:36 PM
Posts: 2,686 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
1000 at the crank is a lot. 3000 is light. At some point one passes into glide territory. I think you might already have.
2011 Drag Pak Challenger
[Re: Jeepmon]
#1864343
07/05/15 03:58 PM
07/05/15 03:58 PM
Al_Alguire
Las Vegas
572 B1, needs a bit more than a standard run of the mill TF obviously. The problem with a PF type deal is they are maintenance heavy in high torque applications and are prone to periodic failure in those applications. Been there done that but no doubt they are quicker that other three speed options like Rossler etc...
[Re: Jeepmon]
#1864392
07/05/15 05:17 PM
07/05/15 05:17 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Powerglide,( or similar)and gear appropriately,never look back.
The torqueflite will need constant repair and maintenance at that level, and the best of best parts. Will it work? Sure. Is it the best choice? My opinion,no. You have lots of power,and you'll always find the weak point.my two cents.
RIP Monte Smith
