What would you do... ?? #1863253
07/04/15 01:45 AM
07/04/15 01:45 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
The trans broke on a 1st to 2nd shift today.. obviously it doesnt like this power level.. I have reverse, but no forward gears.. bawling
So exploring my options, I can pick up a built Glide with all the needed parts for somewhere around $5k... Or I can pick up a used ProFlite with all the bells n whistles and bolt it in and go, for half that amount...
Keeping in mind that California is experiencing a drought and its illegal to water my money tree, I have to be carefull which way I go and there is other things on my "must get" list..
So what would you do?
3000 lbs A-body with 1000hp at the crank.. 456 gears... 34 tall tire..
Re: What would you do... ?? [Re: Jeepmon] #1863255
07/04/15 01:46 AM
07/04/15 01:46 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Listen to the guy on the phone....
Re: What would you do... ?? [Re: Jeepmon] #1863270
07/04/15 02:09 AM
07/04/15 02:09 AM
Cab_Burge Online work
Cab_Burge  Online Work
Proflyte in a California heartbeat up Ask Dave which gear ratios he would want you to run and see how they work twocents 2nd reading, I don't think I would buy a use any brand racing trans unless I drove it from when it was new work twocents
Re: What would you do... ?? [Re: Jeepmon] #1864276
07/05/15 01:58 PM
07/05/15 01:58 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thanks Cab... I'm still not sure what I'm going to do..
Re: What would you do... ?? [Re: Jeepmon] #1864302
07/05/15 02:39 PM
07/05/15 02:39 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
What kind of racing you want to do? I don't think there is one universal answer.
"Just a Bracket car dressed up like a streetcar"
Re: What would you do... ?? [Re: Jeepmon] #1864326
07/05/15 03:12 PM
07/05/15 03:12 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I'd tear it apart and find out what went wrong, then fix it and see what happens.
Re: What would you do... ?? [Re: Jeepmon] #1864331
07/05/15 03:28 PM
07/05/15 03:28 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I think some need to keep in mind the power plant and steam it makes. It is not your average 10 second Mopar deal, just saying and feel free to flame away
Re: What would you do... ?? [Re: Jeepmon] #1864333
07/05/15 03:33 PM
07/05/15 03:33 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
What's the plant ?
Re: What would you do... ?? [Re: Jeepmon] #1864335
07/05/15 03:36 PM
07/05/15 03:36 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
1000 at the crank is a lot. 3000 is light. At some point one passes into glide territory. I think you might already have.
2011 Drag Pak Challenger
Re: What would you do... ?? [Re: Jeepmon] #1864343
07/05/15 03:58 PM
07/05/15 03:58 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
572 B1, needs a bit more than a standard run of the mill TF obviously. The problem with a PF type deal is they are maintenance heavy in high torque applications and are prone to periodic failure in those applications. Been there done that but no doubt they are quicker that other three speed options like Rossler etc...
Re: What would you do... ?? [Re: Jeepmon] #1864392
07/05/15 05:17 PM
07/05/15 05:17 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Powerglide,( or similar)and gear appropriately,never look back.
The torqueflite will need constant repair and maintenance at that level, and the best of best parts. Will it work? Sure. Is it the best choice? My opinion,no. You have lots of power,and you'll always find the weak point.my two cents.
RIP Monte Smith
