MSD COIL BLASTER #186429
01/07/09 01:07 AM
01/07/09 01:07 AM
calif
cupcake Offline OP
cupcake  Offline OP
calif
do,es it realy hurt the coil to mount it on the intake sideways
Re: MSD COIL BLASTER [Re: cupcake] #186430
01/07/09 01:49 AM
01/07/09 01:49 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
They recommend vertical mounting. For sideways spend a few $s more and get the high vibration one:
http://store.summitracing.com/partdetail...mp;autoview=sku
"The High Vibration Coil, PN 8222, can be mounted in any position due to its epoxy potting compound"
Ride eternal, shiny and chrome
Re: MSD COIL BLASTER [Re: DirectSubjection] #186431
01/07/09 08:41 AM
01/07/09 08:41 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
The vibration ends up destroying the seal just inside the terminal area and then it begins to leak oil all over your valleypan and intake, ask me how I know. not to mention you start to notice a weak driveability because your coil wire terminal is bathed in oil
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: MSD COIL BLASTER [Re: Pyper70] #186432
01/07/09 10:25 AM
01/07/09 10:25 AM
MNobody Offline
MNobody  Offline
From the MSD instructions
The Blaster Coil is designed to mount in most factory canister coil mounts. MSD also offers a Chrome Coil Bracket, PN 8213. It is recommended to mount the PN 8202 and 8223 coils in an upright position. The High Vibration Coil, PN 8222, can be mounted in any position due to its epoxy potting compound.
I'm bummed mines been mounted sideway's on the intake for 2 year's, guess i'm gonna have move mine too, hope it ain't trashed. Might explain why i've had cold starting problem's for about a year and a half now.
Re: MSD COIL BLASTER [Re: MNobody] #186433
01/07/09 10:45 AM
01/07/09 10:45 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
MNo,
If you have it on the car in the avatar, then you are probably safe. My coil cooked under the hood because there really isn't any airflow except from that of the mechanical fan. It seems you have a scoop on yours and it wouldn't be damaged. Pop off the coil wire and see if there is any oil, if there isn't just set it upright and I am sure you will be okay. As for hard starting in the morning, maybe your timing is the culprit. I use the timing advance, give her an extra 15 degrees so she is easier to start and then back her down to her normal range as she warms up.
Re: MSD COIL BLASTER [Re: Pyper70] #186434
01/07/09 11:34 AM
01/07/09 11:34 AM
MNobody Offline
MNobody  Offline
Thank's for the info, yes it's on the Dart. Seem's like i read on here somewhere that if you mounted a blaster horizontaly you were supposed the make sure the terminals were turned so they were horizontal and it would be fine, not sure about that though. Gonna move mine anyway, doesn't need to sit on all that heat anyway.
Re: MSD COIL BLASTER [Re: cupcake] #186435
01/07/09 12:13 PM
01/07/09 12:13 PM
AndyF Offline
AndyF  Offline
I started to mfg these little brackets a while back that flip the stock mount from horizontal to vertical. You can buy them from Mancini Racing.
Re: MSD COIL BLASTER [Re: cupcake] #186436
01/07/09 01:01 PM
01/07/09 01:01 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
Mine was mounted horizontal for at least 10 yrs and no problems at all with it.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: MSD COIL BLASTER [Re: MY340] #186437
01/07/09 04:32 PM
01/07/09 04:32 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
Mine has been on for 9 years. No problem at all.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: MSD COIL BLASTER [Re: Prodart440] #186438
01/07/09 07:08 PM
01/07/09 07:08 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Well trust me fella's....I know first hand because I was driving on I-15 headed to Vegas 2 years ago and I popped the hood since she wouldnt crank over after gettin gas. I had to wait 5 hours in the dark until Autozone opened up so I could buy a replacement, mounted it sideways again as I had no means to make an upright bracket in the boonies with no tools and then made a custom vertical bracket out of aluminum when she arrived to her final destination
