B-Body lightweight hood hinge springs #1862834
07/03/15 02:17 PM
07/03/15 02:17 PM
Elk River, Mn.
K
ks66 Offline OP
ks66  Offline OP
K
Elk River, Mn.
I have an AAR bolt-on hood w/WO scoop attached. this is on a 66 Coronet. I would like to find proper lightweight springs that would allow me to not use a prop to hold hood up, but not cause hood warp. what should I look for and where?
Re: B-Body lightweight hood hinge springs [Re: ks66] #1862875
07/03/15 03:33 PM
07/03/15 03:33 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
There usually are lightweight springs available from fiberglass body parts suppliers.
What I did was measured the approximate length I needed and went to a hardware store and found what turned out to be very good springs. It helped to see what springs were supplied by fiberglass replacement hood manufacturers just to know approximately what to look for, but buying at a hardware store, they were cheaper and more quickly available (no shipping).
Re: B-Body lightweight hood hinge springs [Re: D_C] #1863061
07/03/15 09:01 PM
07/03/15 09:01 PM
D_C Offline
D_C  Offline
Here is a similar Moparts Post:
https://board.moparts.org/ubbthreads/ubbt...gs-use-not.html
Supposedly, U.S. body Source sells lightweight hood springs.
http://www.usbodysource.com
Jeg's and Summit Racing also sell lightweight hood springs, though they seem to be listed as being for Chevy's. Not sure if they would work for you or not.
Re: B-Body lightweight hood hinge springs [Re: D_C] #1863132
07/03/15 10:59 PM
07/03/15 10:59 PM
Elk River, Mn.
K
ks66 Offline OP
ks66  Offline OP
K
Elk River, Mn.
Thanks for info. I'll check out US Body source and see what they have.
Re: B-Body lightweight hood hinge springs [Re: ks66] #1865065
07/06/15 01:52 PM
07/06/15 01:52 PM
Springfield, MO
Steve88 Offline
Steve88  Offline
Springfield, MO
I used a pair of trampoline springs on the fiberglass hood on my 67 Chevelle and they worked perfectly. I had a couple extra ones laying around so I thought I would try them just to give me an idea of what I would need and they could not have been any better.
Re: B-Body lightweight hood hinge springs [Re: Steve88] #1865110
07/06/15 02:50 PM
07/06/15 02:50 PM
Alabama
W
WarEagle1 Offline
WarEagle1  Offline
W
Alabama
I bought my hood from VPN and they sell the proper lightweight springs as well. A little pricey but they work well.
Re: B-Body lightweight hood hinge springs [Re: ks66] #1865169
07/06/15 04:09 PM
07/06/15 04:09 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Re: B-Body lightweight hood hinge springs [Re: ks66] #1865497
07/06/15 11:05 PM
07/06/15 11:05 PM
GA
roadrunninMark Offline
GA
VFN Fiberglass has them. That is where I bought mine with the hood. They come chromed. I would like to know how to remove the chrome and paint them correctly (so the paint doesn't come off from opening / closing the hood).
