Challenger T/A Ride Height #1862024
07/02/15 02:27 PM
07/02/15 02:27 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
What is the correct front and rear ride height for a Challenger T/A?
1970 EK2 T/A 727
Re: Challenger T/A Ride Height [Re: f2502011] #1862150
07/02/15 05:12 PM
07/02/15 05:12 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Interesting question, is the AAR the same?
Careful, your character's showing!
Re: Challenger T/A Ride Height [Re: f2502011] #1862182
07/02/15 05:52 PM
07/02/15 05:52 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I believe the front is set to the same spec as any other Challenger. The factory ride height measurement was the difference between two points. Point "A" is the measurement from the ground to the bottom of the torsion bar adjusting blade. Point "B" is the measurement from the ground to the bottom of the LBJ. A minus B = the ride height given in the FSM.
As for the rear, the rear springs were different on the T/A and AAR. The springs gave them an extra 1" of ride height because of the side exit exhaust tips.
Re: Challenger T/A Ride Height [Re: burdar] #1862652
07/03/15 06:14 AM
07/03/15 06:14 AM
US
f2502011 Offline OP
f2502011  Offline OP
US
What are A and B supposed to be? Is there a diagram/picture anywhere online to reference?
1970 EK2 T/A 727
Re: Challenger T/A Ride Height [Re: f2502011] #1862738
07/03/15 11:40 AM
07/03/15 11:40 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Here is a diagram. You need to confirm this but I believe the difference between A&B is 1.75". That measurement seemed way too high on my Challenger. I set the car lower then the spec.
http://i819.photobucket.com/albums/zz112/highplainsperformance/heightmeasure1_zpscf5ba2d8.jpg
Re: Challenger T/A Ride Height [Re: burdar] #1862791
07/03/15 01:06 PM
07/03/15 01:06 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
E bodies would be a 1.125" difference. Chart below on specs. E bodies are car line B&J, by the way.
Also note how aweful, by today's standards, the alignment specs are. I wouldn't encourage anyone to use these unless you have manual steering and bias ply tires.
Re: Challenger T/A Ride Height [Re: f2502011] #1862828
07/03/15 02:05 PM
07/03/15 02:05 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
Thanks for the pics. That last pic must be from later on maybe mid 70s? just looking at the engines listed so I wonder if earlier years may have been different. I'm guessing ultimately the height should be set to my preference, but would there be anything out there T/A or AAR specific anywhere? Maybe an excerpt from a factory assembly manual?
1970 EK2 T/A 727
Re: Challenger T/A Ride Height [Re: f2502011] #1863598
07/04/15 03:36 PM
07/04/15 03:36 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Its a '74 manual, although E bodies did not change through their run.
1970 reproductions can be picked up here on CD, $70 each.
http://moparmanuals.com/mopar/main/home....amp;submit.y=10
You also can search out the dealer service bulletins on AAR/TA models which may have a few tid bits of info. Since non of these are reproduced, that I'm aware of you might start with Hamtramck Historical: http://www.hamtramck-historical.com/
Re: Challenger T/A Ride Height [Re: TC@HP2] #1863684
07/04/15 05:15 PM
07/04/15 05:15 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Didn't know the challengers (J) had such a short wheelbase eek shocked
Re: Challenger T/A Ride Height [Re: Mr340] #1863686
07/04/15 05:18 PM
07/04/15 05:18 PM
Kirkland, Washington
Pacnorthcuda Offline
Good eye!
Re: Challenger T/A Ride Height [Re: Pacnorthcuda] #1864981
07/06/15 12:05 PM
07/06/15 12:05 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Since that's a page from a Plymouth FSM, it does not include Challenger wheelbase specs.
Re: Challenger T/A Ride Height [Re: TC@HP2] #1865118
07/06/15 02:57 PM
07/06/15 02:57 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Actually it does B- barracuda, 108.0 J- challenger 101.0.
the funny thing is I just checked my 73 Dodge FSM and it only show 108 for wheelbase eek
Re: Challenger T/A Ride Height [Re: f2502011] #1865177
07/06/15 04:15 PM
07/06/15 04:15 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
I found this online for 1970 Challenger ride height it says 1". Is that referring to the difference between A and B? It doesn't say on the page in the attached picture.
Re: Challenger T/A Ride Height [Re: f2502011] #1865304
07/06/15 06:22 PM
07/06/15 06:22 PM
MA
steve70 Offline
steve70  Offline
MA
Cuda 108.....Challenger 110
1970 Challenger T/A 4 speed
Re: Challenger T/A Ride Height [Re: f2502011] #1865467
07/06/15 10:36 PM
07/06/15 10:36 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
Is the difference between A and B for a 1970 Challenger T/A 1"?
1970 EK2 T/A 727
Re: Challenger T/A Ride Height [Re: f2502011] #1865778
07/07/15 11:41 AM
07/07/15 11:41 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Exactly, so I wonder how many FSM were published that had the numbers transposed.
