85 W350 transmission lines
#1861890
07/02/15 11:31 AM
07/02/15 11:31 AM
Posts: 516 ND
dodgedon
ND
Where can i find new trans cooler lines for my 85 W350? I called Inline tube and Classic tube with no luck. Inline tube has a listing for a 80-89 W250. Why would this be different? Thanks for any help you can give.
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
Re: 85 W350 transmission lines
[Re: scratchnfotraction]
#1862454
07/02/15 11:32 PM
07/02/15 11:32 PM
Posts: 516 ND
dodgedon
ND
Thanks for your reply scratch. I must agree... How much different could they be? If you can fit a car line with some minor tweaking, then surely another truck line could work...
These are pretty straight forward from the trans ports to the starter stud in the bell. Here they are in a clip together. They step up about 2 inches and continue straight forward to another clip on the front corner of the engine oil pan. From this point one goes into the radiator the other takes a right turn under the crank pulley and then left into the radiator. I just don't see why a W250 would have a different path then this. If any one here has a 80-89 W250 could you confirm or describe your lines??
[Re: dodgedon]
#1867038
07/09/15 01:51 AM
07/09/15 01:51 AM
Posts: 516 ND
dodgedon
ND
Just wanted to give an update. I ordered these lines from Inline Tube. They are part number DTT8731. I used their online order form and said I had a 85 W250. And just to be clear I typed it out in the comment section... "1985 Dodge truck 3/4 ton 4x4 trans cooler lines". What I received was completely identical to what I removed from my W350, so very happy with them. ITs funny that the tech line told me the 1 ton 4x4 was a "completely different animal" and they didnt have a pattern to produce them.
