2006 Ram, full charge, no A/C ? #1861161
07/01/15 12:04 PM
07/01/15 12:04 PM
Cleveland
sunroofgtx Offline OP
Cleveland
The compressor is not kicking on. The mechanic said it has a full charge. I told him him I'll dig in and try to figure out the issue. Any ideas? It's a Cummins 2 wheel drive. Thanks
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: 2006 Ram, full charge, no A/C ? [Re: sunroofgtx] #1861751
07/02/15 01:09 AM
07/02/15 01:09 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
First ck fuses here a diagram
Re: 2006 Ram, full charge, no A/C ? [Re: SALEM1912] #1861757
07/02/15 01:14 AM
07/02/15 01:14 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Clutch wiring, I would ck for power and ground at the clutch first. substitute a reg test light at the harness connector if it lights you know you have power and ground = bad clutch
Re: 2006 Ram, full charge, no A/C ? [Re: sunroofgtx] #1861848
07/02/15 08:58 AM
07/02/15 08:58 AM
ky.
K
kenworth_goose Offline
K
ky.
Just hot wire the clutch to see if it works, if it doesn't work with 12 volts and a ground to it then the coil in the clutch is bad. Either replace the clutch or the compressor. This happened to my 99 ram. Worked fine then quit working all at once. put new compressor and it's just like new.
Re: 2006 Ram, full charge, no A/C ? [Re: kenworth_goose] #1862240
07/02/15 07:00 PM
07/02/15 07:00 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
I went through the same thing early in the spring. Replaced the recirc. door and on start-up had no a/c. work Turned out to be a bad clutch. Just decided to go south at the same time I did the door. blush
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 2006 Ram, full charge, no A/C ? [Re: sunroofgtx] #1862270
07/02/15 07:35 PM
07/02/15 07:35 PM
Cleveland
Cleveland
Hello, thanks, guys. Both fuses are good, 23 and 32. I'll be checking the other tests. Thanks a ton. Sure hope it is something simple. Can't stand it. I have to close the windows to talk on the phone. Long conversations turn quick..lol.. Actually, I might like it like this,...nope..
