e body 4 speed shifter bezel screws #1861652
07/01/15 11:14 PM
07/01/15 11:14 PM
CT,USA
72CUDA340 Offline OP
CT,USA
Can someone tell me what size phillips head screws I need for the trim bezel of the shift boot on a pistol grip? I was hoping to just hit a hardware store and pick up some stainless screws. Thanks
Re: e body 4 speed shifter bezel screws [Re: 72CUDA340] #1861668
07/01/15 11:27 PM
07/01/15 11:27 PM
IN
ahy Offline
ahy  Offline
IN
I used HW store SS screws on mine but it has been a while. Either #8 or #10 x 1" oval head Phillips should do it.
Re: e body 4 speed shifter bezel screws [Re: 72CUDA340] #1862154
07/02/15 05:20 PM
07/02/15 05:20 PM
CT,USA
CT,USA
thanks, is it just the bezel that holds down the boot or do you screw the boot down and then the bezel? I have nothing to go off of since the car was an automatic when I got it. The shifter boot has 8 holes in it so my thinking was that maybe 4 screws go under the bezel and 4 above?
Re: e body 4 speed shifter bezel screws [Re: 72CUDA340] #1862279
07/02/15 07:45 PM
07/02/15 07:45 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
this is how my the boot/bezel is on my 70 challenger. The screw holes in the bezel don't line up with the holes in the boot, so I screwed the boot down, then the bezel. BTW, car was originally manual trans car, had factory cut shifter hole and bezel/boot screw holes.
jt
Yeah, it's hopped up to over 160...
