What shafts for ductile iron rockers? #1860393
06/30/15 11:47 AM
06/30/15 11:47 AM
wellington ohio
68-scatpack-rt Offline OP
In thin ice
In thin ice
wellington ohio
Hello all.
I'm wondering what are the best shafts to use for isky ductile iron rocker arms.
Hardened?
Chrome?
Stock stamped shafts?
Cam is relatively mild. 520ish.
unions....the folks who brought you the weekend!
Re: What shafts for ductile iron rockers? [Re: 68-scatpack-rt] #1860407
06/30/15 12:00 PM
06/30/15 12:00 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
TRW used to make a very good replacement shaft that works well with those rockers.
Re: What shafts for ductile iron rockers? [Re: 68-scatpack-rt] #1860410
06/30/15 12:01 PM
06/30/15 12:01 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
You want hardened shafts, the ductiles will eat the shafts , also banana groove the shaft if it's not.
Re: What shafts for ductile iron rockers? [Re: 68-scatpack-rt] #1860451
06/30/15 12:54 PM
06/30/15 12:54 PM
Isky or RAS shafts for the ductile iron rockers up scope
Re: What shafts for ductile iron rockers? [Re: 68-scatpack-rt] #1860900
06/30/15 10:36 PM
06/30/15 10:36 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Hard chrome shafts from RAS are the best IMO. They are thick wall and have a nice hard chrome treatment like a rod on a hydraulic ram.
Gus beer
64 Plymouth Savoy
Dana 60
Re: What shafts for ductile iron rockers? [Re: 68-scatpack-rt] #1860918
06/30/15 10:48 PM
06/30/15 10:48 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i've had best luck with induction hardened.
Re: What shafts for ductile iron rockers? [Re: 68-scatpack-rt] #1860946
06/30/15 11:38 PM
06/30/15 11:38 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Hard chrome is not the be all, end all. Because it is a coating it can peel and flake under various conditions. Any moisture will cause rust and the chrome bubbles and peels. Likewise, heat can cause it to peel and flake. If there happens to be a flaw in the plating, trouble will start right there.
Hard chrome is not necessary for a nodular iron rocker. The fact that the rockers and shafts are dissimilar metals (iron and steel) minimizes the chances of problems arising as long as they're well lubed.
FWIW, when the factory put iron rockers on various motors they used a plain ol' shaft - nothing fancy. And aftermarket iron rockers worked fine on stock shafts - the only problem with stockers being that they were thin walled and prone to being squeezed oval when tightening the hold downs, making rocker removal a [censored]! Hemis were the only motors with iron rockers that got bushings.
Buy a quality steel shaft and you'll do just fine.
Re: What shafts for ductile iron rockers? [Re: 68-scatpack-rt] #1861008
07/01/15 01:17 AM
07/01/15 01:17 AM
Vermont
bracketcharger Offline
Vermont
Not looking to hijack but has anyone used the Hughes rocker shafts with ductile iron rockers ? I'm looking at crane ductile iron rockers for my 440. Thanks.
Re: What shafts for ductile iron rockers? [Re: Stanton] #1861013
07/01/15 01:28 AM
07/01/15 01:28 AM
I think that the M.W and 340 T/A motors came with bushed ductile iron rockers also work Maybe not confused You couldn't use a ductile iron rocker on a stock stamp steel rocker arm shaft, they would gall up and ruined the rockers after a while, been there done that,shruggy Made that mistake twice realcrazy
Re: What shafts for ductile iron rockers? [Re: 68-scatpack-rt] #1861119
07/01/15 10:54 AM
07/01/15 10:54 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I had two motors, one with Iskys and the other with Cranes. Both with stock shafts and tons of street miles with ZERO problems. Pretty sure only the hemi rockers were bushed.
Anyway, its a moot point since we're all advising a decent aftermarket shaft. My main point was that hard chrome is not a necessity in this case.
Re: What shafts for ductile iron rockers? [Re: 68-scatpack-rt] #1861121
07/01/15 10:56 AM
07/01/15 10:56 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
max wedge wasn't bushed.
Re: What shafts for ductile iron rockers? [Re: 68-scatpack-rt] #1861148
07/01/15 11:53 AM
07/01/15 11:53 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
TA rockers are not bushed...
Tony
70 AARCuda Vitamin C
Re: What shafts for ductile iron rockers? [Re: 68-scatpack-rt] #1861235
07/01/15 01:35 PM
07/01/15 01:35 PM
wellington ohio
In thin ice
In thin ice
wellington ohio
I called RAS yesterday.
He's waiting on shafts right now.
I'm going to send the whole shooting match to him over the winter.
On a side note, how are you guys making the banana grooves? Free hand with a die grinder?
Re: What shafts for ductile iron rockers? [Re: 68-scatpack-rt] #1861276
07/01/15 02:23 PM
07/01/15 02:23 PM
RAs will do all that is needed on your shafts up
Re: What shafts for ductile iron rockers? [Re: 68-scatpack-rt] #1861399
07/01/15 05:32 PM
07/01/15 05:32 PM
wellington ohio
In thin ice
In thin ice
wellington ohio
I know the ras shafts are grooved.
I'm looking to groove some production shafts to get me by.
Re: What shafts for ductile iron rockers? [Re: 68-scatpack-rt] #1861749
07/02/15 01:06 AM
07/02/15 01:06 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
...On a side note, how are you guys making the banana grooves? Free hand with a die grinder?
Yeah, that's what I did..but I went with a straight cut, as opposed to the angled one (I can't imagine how you'd do an angled cut free-hand like that on a round surface)...haven't run the new setup yet (Crane ductile iron 1.6 ratio) so can't comment on whether that home-made bannana groving job worked or not.
