What shafts for ductile iron rockers?
#1860393
06/30/15 11:47 AM
06/30/15 11:47 AM
Posts: 1,144 wellington ohio
68-scatpack-rt
In thin ice
In thin ice
wellington ohio
Hello all. I'm wondering what are the best shafts to use for isky ductile iron rocker arms.
Hardened?
Chrome?
Stock stamped shafts?
Cam is relatively mild. 520ish.
unions....the folks who brought you the weekend!
Re: What shafts for ductile iron rockers?
[Re: 68-scatpack-rt]
#1860410
06/30/15 12:01 PM
06/30/15 12:01 PM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
You want hardened shafts, the ductiles will eat the shafts , also banana groove the shaft if it's not.
#1860900
06/30/15 10:36 PM
06/30/15 10:36 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Hard chrome shafts from RAS are the best IMO. They are thick wall and have a nice hard chrome treatment like a rod on a hydraulic ram. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Stanton]
#1861013
07/01/15 01:28 AM
07/01/15 01:28 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
Hemis were the only motors with iron rockers that got bushings.
Buy a quality steel shaft and you'll do just fine. I think that the M.W and 340 T/A motors came with bushed ductile iron rockers also Maybe not You couldn't use a ductile iron rocker on a stock stamp steel rocker arm shaft, they would gall up and ruined the rockers after a while, been there done that, Made that mistake twice
#1861119
07/01/15 10:54 AM
07/01/15 10:54 AM
Posts: 8,882 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
You couldn't use a ductile iron rocker on a stock stamp steel rocker arm shaft, they would gall up and ruined the rockers after a while, been there done that I had two motors, one with Iskys and the other with Cranes. Both with stock shafts and tons of street miles with ZERO problems. Pretty sure only the hemi rockers were bushed. Anyway, its a moot point since we're all advising a decent aftermarket shaft. My main point was that hard chrome is not a necessity in this case.
#1861148
07/01/15 11:53 AM
07/01/15 11:53 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
TA rockers are not bushed...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
#1861235
07/01/15 01:35 PM
07/01/15 01:35 PM
68-scatpack-rt
In thin ice
In thin ice
wellington ohio
I called RAS yesterday. He's waiting on shafts right now. I'm going to send the whole shooting match to him over the winter.
On a side note, how are you guys making the banana grooves? Free hand with a die grinder?
#1861399
07/01/15 05:32 PM
07/01/15 05:32 PM
68-scatpack-rt
In thin ice
In thin ice
wellington ohio
I know the ras shafts are grooved.
I'm looking to groove some production shafts to get me by.
#1861749
07/02/15 01:06 AM
07/02/15 01:06 AM
Posts: 1,761 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
I called RAS yesterday. ...On a side note, how are you guys making the banana grooves? Free hand with a die grinder? Yeah, that's what I did..but I went with a straight cut, as opposed to the angled one (I can't imagine how you'd do an angled cut free-hand like that on a round surface)...haven't run the new setup yet (Crane ductile iron 1.6 ratio) so can't comment on whether that home-made bannana groving job worked or not.
