Re: Alignment Specs for my 69 Satellite Wagon
[Re: Sneke_Eyez]
#1860208
06/30/15 02:36 AM
06/30/15 02:36 AM
Posts: 27,465 So Cal
autoxcuda
So Cal
1.5 neg camber on the street even with aggressive driving will wear inside faster in 8,000 miles. Noticing that on my car. Not really faster. But noticeable in 8,000 miles.
I think i'd go 1.0 neg camber or .75
On a that wagon with thin side walls: .75 neg camber.
[Re: autoxcuda]
#1860507
06/30/15 02:07 PM
06/30/15 02:07 PM
Posts: 321 Massachusetts
Sneke_Eyez
Massachusetts
On a that wagon with thin side walls: .75 neg camber. Thank you, I was hoping you would weigh in. So 1.0 neg camber or .75? Then what settings for everything else? Total Toe is obviously .12 degree in with ~1/16 toe in Caster settings? 4.5? I have the same offset bushings you do, I bet the guy could do it. Is caster something I should have balanced with camber?
1969 Satellite Wagon - G3 Hemi Swap Incoming. | 1969 Coronet Post Coupe. 2002 Intrepid ES | 2009 Ram SLT | 2004 300M Special | 2002 300M Pro Am - Hers
Are you a New England Mopar Enthusiast? Come check out the revived NorthEast Mighty Mopar at www.northeastmightymopar.com!
[Re: Sneke_Eyez]
#1860926
06/30/15 11:01 PM
06/30/15 11:01 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
You can't achieve enough caster with stock arms to begin with. So you align to as much caster as possible while still ending up with a livable amount of negative camber as Steve suggested.
Mopar to the bone!!!
[Re: Sneke_Eyez]
#1861282
07/01/15 02:31 PM
07/01/15 02:31 PM
Posts: 5,387 Pikes Peak Country
TC@HP2
Pikes Peak Country
doesn't camber keep the contact patch in the turns while caster helps the car go in a straight line ? also, how much cross caster/camber is acceptable ? Yes, in its static settings they do exactly that. However, camber and caster also have a dynamic side that occurs when the suspension moves through its travel. Higher caster not only produces straight line stability but also increases steering effort ( good for offsetting some of that mopar over-assist in power systems) increases return to center characteristics (so the steering self centers faster), and most importantly creates greater dynamic negative camber gain. So with 2* positive caster and zero camber, you may get 1/2* of negative camber as the outside tire compresses. However, step up caster to 6* and you may now gain 1.5* of negative camber in the same wheel travel. That is a huge increase in maintaining tread contact while the body rolls around its axis. This is why in stock form, 1st gen Camaros are such handling turds. They go into positive camber under compression. The exact opposite of what you want for handling. That's yet another reason why there are so many modification to and suspension companies for GM products. .75 Negative Camber As Much Caster As Possible, but keeping both sides even 0.12 ~1/16" toe in
Sound like a plan that will handle well and keep me satisfied?
Yes, that is a great goal for all around street performance.
[Re: Sneke_Eyez]
#1885712
08/05/15 04:43 PM
08/05/15 04:43 PM
Sneke_Eyez
Massachusetts
Finally having the thing aligned tomorrow to these specs: (Literally giving the guy this spec sheet, though I already talked to him about it and he said it sounded ok to him.)
Camber .75 degree negative or as close as possible to that with both sides even
Caster As much as possible with both sides even (I’ve been told 4.5 positive is possible on these with these control arm bushings, but if it can’t go that high due to the camber I want, so be it)
Toe-In .12 degrees/~1/16’’
I'll report back with my experiences and how the car feels. Mainly I just can't wait to drive the damn thing again.
[Re: krautrock]
#1885767
08/05/15 06:04 PM
08/05/15 06:04 PM
Sneke_Eyez
Massachusetts
you got the caster and camber backwards
you want as much caster as you can get and less then a full degree of negative camber... Ha, yes I did, good catch! THANKS! Changed up top to avoid confusion for others in the future. I did this at work and apparently didn't pay attention to which heading I was typing in - luckily I decided to post it on Moparts!
[Re: Sneke_Eyez]
#1916722
09/21/15 02:29 PM
09/21/15 02:29 PM
Sneke_Eyez
Massachusetts
The shop where it was supposed to get done cancelled on me because it is a one man affair and he got sick. I wanted to get it out on the road and drive it, so I took it to my regular shop that does all types of repair and gave them the specs.
Car got aligned, I'm happy with it, but I'm not sure that they did it exactly to spec because they forgot to print out the sheet for me. I asked for the sheet specifically and they didn't do it, and my father delivered the car to the shop and picked it up for me, so he didn't realize that they didn't give it to him. When I called and asked for it later, they said they couldn't do it.
I don't know why making the printout is so hard, especially for a shop that I generally find very competent.
It drives quite nicely now, and with some additional upgrades made this summer (Hotchkis Fox shocks, Hellwig rear sway bar), it can really wrap around the twisties.
I will continue to drive it and will likely post an update to another thread I made in this section soon.
