lower linkage brkt. floor shift #1859101
06/28/15 08:14 PM
06/28/15 08:14 PM
budd12 Offline OP
budd12  Offline OP
where does the lower bracket mount for the stock floor console shifter on a 1972 A body. can't find where to mount it?????
Re: lower linkage brkt. floor shift [Re: budd12] #1860110
06/30/15 12:03 AM
06/30/15 12:03 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If it uses the flat bar with the 90 degree bend at the end, it attaches to two holes at the bottom of the trans tailstock.I believe the holes are tight in front of the trans mount. Its been many years. Gene
