Where to buy - Distributor shaft bushing/roll pin? #185902
01/06/09 07:25 PM
01/06/09 07:25 PM
Farmland, IN
Ludington1 Offline OP
Farmland, IN
Where can I find the plastic bushing and roll pin that goes in the distributor shaft and holds it against the housing? I've got a cracked one here, and checked Rock Auto and Advance and don't see it listed anywhere.
Thanks Moparts!
Darren
Re: Where to buy - Distributor shaft bushing/roll pin? [Re: Ludington1] #185903
01/06/09 07:32 PM
01/06/09 07:32 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
That's a good question. The roll pin can be got at most hardware stores. The plastic collar is a whole different deal. I'm thinking you might have to get a old dist. to get the collar.
Maybe someone else knows where to get one?
Good luck and a
Re: Where to buy - Distributor shaft bushing/roll pin? [Re: Challenger 1] #185904
01/06/09 07:57 PM
01/06/09 07:57 PM
Cochise County Arizona
SPWC Offline
SPWC  Offline
I think the Plastic gear and roll pin for a /6 is still available through the dealer,I dont see why the plastic collar and Roll pin for a V8 dizzy wouldnt be.
Re: Where to buy - Distributor shaft bushing/roll pin? [Re: SPWC] #185905
01/06/09 08:03 PM
01/06/09 08:03 PM
Cincinnati, Ohio
Cincinnati, Ohio
Good idea... you guys got any dealers left nearby?
Re: Where to buy - Distributor shaft bushing/roll pin? [Re: Challenger 1] #185906
01/06/09 08:05 PM
01/06/09 08:05 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Last time I needed one they were still available through the dealer.
Re: Where to buy - Distributor shaft bushing/roll pin? [Re: Challenger 1] #185907
01/06/09 08:07 PM
01/06/09 08:07 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
Sounds like something you could get from mcmastercar (www.mcmaster.com) It is just a sleeve with a hole in it.
A brass or a steel one would work (if you use steel buy a nylon washer to go between the bushing and the dist. Hell you could make a drill stop work if you had some time...
Also a machinist should be able to make one w/o any trouble it is just some round stock w/ a hole in the center w/a hole for the roll pin.
Re: Where to buy - Distributor shaft bushing/roll pin? [Re: 6T6Cuda] #185908
01/06/09 08:12 PM
01/06/09 08:12 PM
Farmland, IN
Farmland, IN
I was actually wondering... I've got a collar with a set screw, 1/2" inside diameter, I guess that would work? I can try the dealer tomorrow, but I haven't had much luck with parts guys at the local dealer being interested in looking things up.
Thanks,
Darren
Re: Where to buy - Distributor shaft bushing/roll pin? [Re: 6T6Cuda] #185909
01/06/09 08:12 PM
01/06/09 08:12 PM
Cincinnati, Ohio
Cincinnati, Ohio
or
I was thinking about washers or sleeve to control end play and install the roll pin and be done.
Re: Where to buy - Distributor shaft bushing/roll pin? [Re: Ludington1] #185910
01/06/09 08:56 PM
01/06/09 08:56 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
What is the part number of the distributor?
Re: Where to buy - Distributor shaft bushing/roll pin? [Re: Snoopy] #185911
01/06/09 09:07 PM
01/06/09 09:07 PM
Farmland, IN
Farmland, IN
It is the original from my 69 R/T, not sure what the part number is, I will have to look at it tomorrow.
Thanks guys... had a few strange questions this week.
Darren
Re: Where to buy - Distributor shaft bushing/roll pin? [Re: Ludington1] #185912
01/06/09 09:14 PM
01/06/09 09:14 PM
BFE
blue67440's Offline
blue67440's  Offline
BFE
There was someone selling new ones on ebay a few months back, did you look there?
XP29L72 A833 in 881 XP29L72 A727 in 881
Re: Where to buy - Distributor shaft bushing/roll pin? [Re: Ludington1] #185913
01/06/09 09:15 PM
01/06/09 09:15 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Hey Darren, what's up. If you get the # I can check my stash. If it's the old style it's a bushing and a washer, newer style is all together. I have a bunch of old dist around, just did the same for the RR. If I don't have one, and I'm sure I may, my neighbor works at Hollywood Chrysler/Jeep and he could find it if it's avalible. Drop me a line. John
Re: Where to buy - Distributor shaft bushing/roll pin? [Re: blue67440's] #185914
01/06/09 09:18 PM
01/06/09 09:18 PM
Snoopy Offline
Snoopy  Offline
This is the part number, 2084448, for the service package for a 383 & 440 single point distributors. Maybe someone can supply the superseded part numbers.
Re: Where to buy - Distributor shaft bushing/roll pin? [Re: Snoopy] #185915
01/06/09 09:30 PM
01/06/09 09:30 PM
Farmland, IN
Farmland, IN
Thanks everyone! If someone can get a current part number, that will make the local parts guys a lot more pleasant to deal with.
John - I appreciate it, mine is the plastic collar with the thin washer between it and the distributor housing.
Thanks,
Darren
Re: Where to buy - Distributor shaft bushing/roll pin? [Re: Ludington1] #185916
01/06/09 09:42 PM
01/06/09 09:42 PM
Farmland, IN
Farmland, IN
I got a very nice PM from a member, so consider this one solved. Only remaining problem is that his PM box if full!
Darren
Re: Where to buy - Distributor shaft bushing/roll pin? [Re: Ludington1] #185917
01/06/09 10:34 PM
01/06/09 10:34 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Darren
Mine's not!
Re: Where to buy - Distributor shaft bushing/roll pin? [Re: Challenger 1] #185918
01/06/09 10:40 PM
01/06/09 10:40 PM
the boonies
aarcuda Online content
aarcuda  Online Content
the boonies
or
thats funny. i broke the collar on mine trying to shim up the end play on my distributor. got the pin out and the right thickness washer in there but when I tried to put the pin back in, it broke the collar.
stole a collar off another distributor and the hole didnt line up just right and broke that one too.
the third time was the charm though.... i used a drill to make sure the pin would catch the collar and break it.
lesson here is BE CAREFUL PUTTING THE PIN THROUGH
Re: Where to buy - Distributor shaft bushing/roll pin? [Re: aarcuda] #185919
01/06/09 10:47 PM
01/06/09 10:47 PM
Upper Midwest
Upper Midwest
AMEN to that. Especially the old brittle used ones.
Re: Where to buy - Distributor shaft bushing/roll pin? [Re: MoparforLife] #185920
01/06/09 10:48 PM
01/06/09 10:48 PM
the boonies
the boonies
yup, the used ones got old and hot = brittle.
Re: Where to buy - Distributor shaft bushing/roll pin? [Re: aarcuda] #185921
01/06/09 11:16 PM
01/06/09 11:16 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
I did the EXACT same thing......
I took my cracked one to a friend of mine and he made me a pair of them out of aluminum.
