Re: Where to buy - Distributor shaft bushing/roll pin?
[Re: Ludington1]
#185903
01/06/09 07:32 PM
01/06/09 07:32 PM
Challenger 1
Cincinnati, Ohio
That's a good question. The roll pin can be got at most hardware stores. The plastic collar is a whole different deal. I'm thinking you might have to get a old dist. to get the collar. Maybe someone else knows where to get one? Good luck and a
[Re: SPWC]
#185905
01/06/09 08:03 PM
01/06/09 08:03 PM
Challenger 1
Cincinnati, Ohio
I think the Plastic gear and roll pin for a /6 is still available through the dealer,I dont see why the plastic collar and Roll pin for a V8 dizzy wouldnt be.
Good idea... you guys got any dealers left nearby?
[Re: 6T6Cuda]
#185908
01/06/09 08:12 PM
01/06/09 08:12 PM
Posts: 3,072 Farmland, IN
Ludington1
Farmland, IN
Sounds like something you could get from mcmastercar (www.mcmaster.com) It is just a sleeve with a hole in it.
A brass or a steel one would work (if you use steel buy a nylon washer to go between the bushing and the dist. Hell you could make a drill stop work if you had some time...
Also a machinist should be able to make one w/o any trouble it is just some round stock w/ a hole in the center w/a hole for the roll pin.
I was actually wondering... I've got a collar with a set screw, 1/2" inside diameter, I guess that would work? I can try the dealer tomorrow, but I haven't had much luck with parts guys at the local dealer being interested in looking things up.
Thanks, Darren
[Re: 6T6Cuda]
#185909
01/06/09 08:12 PM
01/06/09 08:12 PM
Challenger 1
Cincinnati, Ohio
or
I was thinking about washers or sleeve to control end play and install the roll pin and be done.
[Re: Ludington1]
#185912
01/06/09 09:14 PM
01/06/09 09:14 PM
Posts: 493 BFE
blue67440's
BFE
There was someone selling new ones on ebay a few months back, did you look there?
XP29L72 A833 in 881
XP29L72 A727 in 881
[Re: Ludington1]
#185913
01/06/09 09:15 PM
01/06/09 09:15 PM
Posts: 3,407 S.E. Florida, USA
rrunner
S.E. Florida, USA
Hey Darren, what's up. If you get the # I can check my stash. If it's the old style it's a bushing and a washer, newer style is all together. I have a bunch of old dist around, just did the same for the RR. If I don't have one, and I'm sure I may, my neighbor works at Hollywood Chrysler/Jeep and he could find it if it's avalible. Drop me a line. John
[Re: Snoopy]
#185915
01/06/09 09:30 PM
01/06/09 09:30 PM
Ludington1
Farmland, IN
Thanks everyone! If someone can get a current part number, that will make the local parts guys a lot more pleasant to deal with. John - I appreciate it, mine is the plastic collar with the thin washer between it and the distributor housing. Thanks, Darren
[Re: Ludington1]
#185917
01/06/09 10:34 PM
01/06/09 10:34 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
I got a very nice PM from a member, so consider this one solved. Only remaining problem is that his PM box if full!
Darren
Mine's not!
[Re: Challenger 1]
#185918
01/06/09 10:40 PM
01/06/09 10:40 PM
Posts: 15,489 the boonies
aarcuda
the boonies
or
thats funny. i broke the collar on mine trying to shim up the end play on my distributor. got the pin out and the right thickness washer in there but when I tried to put the pin back in, it broke the collar.
stole a collar off another distributor and the hole didnt line up just right and broke that one too.
the third time was the charm though.... i used a drill to make sure the pin would catch the collar and break it.
lesson here is BE CAREFUL PUTTING THE PIN THROUGH
[Re: aarcuda]
#185919
01/06/09 10:47 PM
01/06/09 10:47 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
AMEN to that. Especially the old brittle used ones.
[Re: MoparforLife]
#185920
01/06/09 10:48 PM
01/06/09 10:48 PM
aarcuda
the boonies
yup, the used ones got old and hot = brittle.
