Re: Electric Fuel Pump
[Re: JFChallenger440]
#1857479
06/26/15 04:32 PM
06/26/15 04:32 PM
Andrewh
#1857817
06/27/15 12:21 AM
06/27/15 12:21 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
If you go with an electric pump I will say I was very pleased running the Holley red pump for years on my mild 11 and 12 second builds. Its nice for a basically stock V/8 also as it has built in regulation so you dont have to put in an external pressure regulator anywhere. Its preset at about 6 psi I believe and I ran them for many years with good luck. Ron
#1858068
06/27/15 12:02 PM
06/27/15 12:02 PM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
Having been thru the "too short" pushrod dilema with my Hemi & 383, electric gerotor style pumps were the perfect fix. No vapor lock issues on hot days with crap pump gas, either. The Holley gerotor pump for the Challenger's Hemi & the Mallory gerotor pump on Power Wagon. Both super quiet, with the Mallory pump even quieter than the Holley. No way would I use a Holley vane pump since they're way too loud for me. Mount the pump behind the tank & install a return line & you should have many miles of trouble & noise free crusing. Also, both pumps are available in higher gph models as well. The Holley http://www.summitracing.com/nv/parts/hly-12-125/overview/Mallory http://www.summitracing.com/nv/parts/msd-29256
#1858134
06/27/15 01:49 PM
06/27/15 01:49 PM
383man
Balt. Md
Is this the one you mean ? Is it noisy ? Also if I buy one without the built in regulator what pressure should it be regulated to ideally ? And regarding the pushrod, what length should it be ? Because I will take my current one out and see if it's worn http://www.ebay.co.uk/itm/Holley-12-801-...=item3f4b013001 Yes thats the one. If you mount it with the rubber pad under it then its not super loud but it is a bit noisey. If you run a pump with external regulater then shoot for about 5 to 6 psi. Actually any pump you use should be mounted with a rubber gasket between the pump and the body. Ron
