Electric Fuel Pump #1857474
06/26/15 04:20 PM
06/26/15 04:20 PM
London, England
JFChallenger440 Offline OP
London, England
I want to upgrade to an electric fuel pump on my 69 Coronet 383, I was just wondering if there are any particular ones I should go for ? Any recommendations ? Thanks
Re: Electric Fuel Pump [Re: JFChallenger440] #1857479
06/26/15 04:32 PM
06/26/15 04:32 PM
Andrewh Offline
Andrewh  Offline
carb or efi?
Re: Electric Fuel Pump [Re: Andrewh] #1857516
06/26/15 05:44 PM
06/26/15 05:44 PM
London, England
London, England
Sorry, carb, 4 barrel Holley
Re: Electric Fuel Pump [Re: JFChallenger440] #1857532
06/26/15 05:57 PM
06/26/15 05:57 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Stock or modified engine?
I've had good luck with the off-brand pumps. I found best reults with mounting the pump back by the tank and using a rubber or foam isolated clamp so the bolts that mount the clamp to the frame do not touch the pump itself.
Re: Electric Fuel Pump [Re: DaytonaTurbo] #1857539
06/26/15 06:10 PM
06/26/15 06:10 PM
London, England
London, England
It's pretty much stock from what I can tell, not had the car long
Re: Electric Fuel Pump [Re: JFChallenger440] #1857565
06/26/15 06:37 PM
06/26/15 06:37 PM
London, England
London, England
I would keep the mechanical pump but I think the problem why I keep breaking down is a worn pushrod, any idea which one I need for a 383 ? Would this be ok ?
http://www.jegs.com/webapp/wcs/stores/se...p;storeId=10001
Re: Electric Fuel Pump [Re: JFChallenger440] #1857630
06/26/15 08:07 PM
06/26/15 08:07 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Yes it would but you could get it at NAPA. have you looked at the old one? this isn't a part that is sometimes good and sometimes bad. it's either worn and too short (or the cam lobe) or it's good.
Re: Electric Fuel Pump [Re: JFChallenger440] #1857817
06/27/15 12:21 AM
06/27/15 12:21 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
If you go with an electric pump I will say I was very pleased running the Holley red pump for years on my mild 11 and 12 second builds. Its nice for a basically stock V/8 also as it has built in regulation so you dont have to put in an external pressure regulator anywhere. Its preset at about 6 psi I believe and I ran them for many years with good luck. Ron
Re: Electric Fuel Pump [Re: 383man] #1857987
06/27/15 06:19 AM
06/27/15 06:19 AM
London, England
London, England
Is this the one you mean ?
Is it noisy ? Also if I buy one without the built in regulator what pressure should it be regulated to ideally ?
And regarding the pushrod, what length should it be ? Because I will take my current one out and see if it's worn
http://www.ebay.co.uk/itm/Holley-12-801-...=item3f4b013001
Re: Electric Fuel Pump [Re: JFChallenger440] #1858068
06/27/15 12:02 PM
06/27/15 12:02 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Having been thru the "too short" pushrod dilema with my Hemi & 383,
electric gerotor style pumps were the perfect fix. No vapor lock issues on hot days with crap pump gas, either. The Holley gerotor pump for the Challenger's Hemi & the Mallory gerotor pump on Power Wagon. Both super quiet, with the Mallory pump even quieter than the Holley. No way would I use a Holley vane pump since they're way too loud for me. Mount the pump
behind the tank & install a return line & you should have many miles of trouble & noise free crusing. Also, both pumps are available in higher gph models as well.
The Holley http://www.summitracing.com/nv/parts/hly-12-125/overview/
Mallory http://www.summitracing.com/nv/parts/msd-29256
Re: Electric Fuel Pump [Re: JFChallenger440] #1858134
06/27/15 01:49 PM
06/27/15 01:49 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes thats the one. If you mount it with the rubber pad under it then its not super loud but it is a bit noisey. If you run a pump with external regulater then shoot for about 5 to 6 psi. Actually any pump you use should be mounted with a rubber gasket between the pump and the body. Ron
Re: Electric Fuel Pump [Re: JFChallenger440] #1858450
06/27/15 10:21 PM
06/27/15 10:21 PM
Manitoba, Canada
Manitoba, Canada
If you mount the pump the way I explained you will find it quiets them down a ton.
Re: Electric Fuel Pump [Re: JFChallenger440] #1858772
06/28/15 11:45 AM
06/28/15 11:45 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
those electric pumps are over-kill for what he described above. a simple carter street pump 5-7 psi is all he needs. they work awesome and last forever. and no regulator to fuss with. better yet, fix what ya got!
Re: Electric Fuel Pump [Re: mikemee1331] #1859416
06/29/15 01:17 AM
06/29/15 01:17 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Electric pumps are much better for fighting vapor lock. And the Holley red pump does not need an external regulator as thats what I liked about it. Ron
