No acc power or power to ignition wires under hood #1858275
06/27/15 05:41 PM
06/27/15 05:41 PM
kentucky
roadrunner7020 Offline OP
kentucky
I'm helping a friend work on a 67 barracuda we put all new headlight and engine harness on the car as it was a rats nest before. We went to start the car today and I don't have and I have power to the headlights brakelights but I don't have any power to any accessories radio etc nor the ignition wires to the electronic ignition box etc. I pulled the ignition switch and it has bench test good but it seems like I don't have power to it maybe any advice? Thanks in advance.
Re: No acc power or power to ignition wires under hood [Re: roadrunner7020] #1858287
06/27/15 05:57 PM
06/27/15 05:57 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Do you have power in and out of the amp gauge?
Re: No acc power or power to ignition wires under hood [Re: roadrunner7020] #1858297
06/27/15 06:08 PM
06/27/15 06:08 PM
kentucky
kentucky
I have power at the fusible link going in and the alternator feed which if I recall is the other side of the ammeter
Re: No acc power or power to ignition wires under hood [Re: roadrunner7020] #1858309
06/27/15 06:26 PM
06/27/15 06:26 PM
kentucky
kentucky
Anything that would be a key on only power isn't getting power in any position of the key including the fuse box
Re: No acc power or power to ignition wires under hood [Re: roadrunner7020] #1858345
06/27/15 08:18 PM
06/27/15 08:18 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
If you have power on the alternator lead and the fusible link unless something else is amiss you've completed the circuit through the ammeter. Do you have power to the ignition switch? You should as the black wire coming off the ammeter turns to a red wire in a splice and goes directly to the ignition switch. I'd start at the switch and work my way to the fuse block. With a '67 at least you can pull the switch out easily for trouble shooting.
Re: No acc power or power to ignition wires under hood [Re: roadrunner7020] #1858364
06/27/15 08:39 PM
06/27/15 08:39 PM
kentucky
kentucky
I think I found the problem I pulled the plug away from the switch and examined it the power wore is missing from the plug.... That will do it any advice on the best way to disassemble the dash and find the wire?
Re: No acc power or power to ignition wires under hood [Re: roadrunner7020] #1858391
06/27/15 09:34 PM
06/27/15 09:34 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
My suggestion, don't disassemble any more than you have to. It sounds like you didn't replace the instrument panel wiring harness so I am assuming that it follows the FSM wiring diagrams. I'd follow the black wire from the ammeter. It goes to a splice that has a black w/tracer, another black wire, red w/tracer, and red. The red one is supposed to go to the ignition switch. Good luck.
Re: No acc power or power to ignition wires under hood [Re: roadrunner7020] #1859462
06/29/15 02:41 AM
06/29/15 02:41 AM
kentucky
kentucky
The barracuda is up and running under its new 408 power plant thanks all.
