Lets see your stereo installations
#1857035
06/25/15 09:55 PM
06/25/15 09:55 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I'd like to see your radio/stereo installations. I don't know if anyone makes a cd player that will fit in the stock dash of a '72 Duster? I'm guessing it would be expensive. I've seen some nice installations in the glove box but I really don't want to reach over that far to mess with it while driving. I was thinking maybe a slide-out tray under the dash but it'd probably get in the way if I had to work on wires under the dash, maybe not.
I have a stock radio in my dash, I don't even know if it works.
Re: Lets see your stereo installations
[Re: ProSport]
#1857517
06/26/15 05:44 PM
06/26/15 05:44 PM
Posts: 416 Georgia
KingTuna
Georgia
I don't have pics, I had an under the dash mount in my 73 Cutlass. Doesn't some company make a old looking radio with modern internals?
2014 Ram 1500 Pentastar V6 1966 Fury II 4 door
[Re: ProSport]
#1857594
06/26/15 07:20 PM
06/26/15 07:20 PM
Posts: 13,605 md
mopars4ever
md
[Re: mopars4ever]
#1857669
06/26/15 08:36 PM
06/26/15 08:36 PM
Posts: 3,967 S.I. N.Y.
1MYTGTX
S.I. N.Y.
In the glovebox with a wired remote...nothing special...
1MYTGTX
[Re: ProSport]
#1858021
06/27/15 10:23 AM
06/27/15 10:23 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
No pictures but I can get one if needed. I choose to go with an Ipod and the small Mr.Beats Pill. The main reason and advantage for me is I can move it from car to car so I only had to buy 1 set up and it was fairly inexpensive. I can get up to about 7 hours on 1 charge which does most trips for me, I have working cigarette lighters in most everything so I can keep it alive indefinitely. Not a CD but as you know you can put what you want on it and it even has access to AM/FM if desired. My main concern was originality and expense due the body count needed. If I had it to do over I would buy the bigger pill.
They also make stereos with wireless remotes allowing for trunk mount and easy access to controls, speaker location would be the concern there.
Careful, your character's showing!
[Re: 1MYTGTX]
#1858781
06/28/15 11:59 AM
06/28/15 11:59 AM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
In the glovebox with a wired remote...nothing special... don't mean to hijack, were does one find the reverse shift pattern for the console shifter in this pic? need to buy one please? as for my radio no pic, but put a restro style radio in my 70 b body, it has a cord that I put in the ashtray, plug in my ubs close ashtray all looks good, I did by another correct radio plate to save my original one.
[Re: ProSport]
#1858905
06/28/15 02:56 PM
06/28/15 02:56 PM
ProSport
Akron, Ohio
BigMoneyLewis and 72RoadrunnerGTX, what did your radios cost? They look pricey.
I'm starting to think the only affordable and easily accessible option is to carefully cut the dash for an affordable FM CD player. My Duster has a motor plate and 500" engine but other than that it's all stock steel and uncut or modified. Decisions Decisions.
[Re: ProSport]
#1858912
06/28/15 03:03 PM
06/28/15 03:03 PM
meepmeep70
weymouth,mass.
I'm starting to think the only affordable and easily accessible option is to carefully cut the dash for an affordable FM CD player. My Duster has a motor plate and 500" engine but other than that it's all stock steel and uncut or modified. Decisions Decisions. is the plastic piece on dash were radio will mount replaceable? on my 70 road runner the "radio plate" didn't support the radio I bought from retro style (knobs on both sides) so I bought another radio plate from a member here, saved my original and slightly trimmed the piece I bought, can replace it with the original anytime
[Re: ProSport]
#1858924
06/28/15 03:19 PM
06/28/15 03:19 PM
ProSport
Akron, Ohio
The plastic piece is just a trim piece, iirc the metal dash is cut to fit the radio perfectly and would not fit an aftermarket cd player without cutting the dash. I'll try to look at it more today.
[Re: ProSport]
#1859492
06/29/15 08:19 AM
06/29/15 08:19 AM
Posts: 4,247 Alabama
BigMoneyLewis
Alabama
BigMoneyLewis and 72RoadrunnerGTX, what did your radios cost? They look pricey We can convert just about any 60's-mid 70's radio to modern AM FM stereo with the ability to run up to 4 speakers , 180 watts total power with aux jacks for $ 469 including return shipping. This is the way most people are going because they want the radio to remain 100 % original in appearance for car shows and judging etc. plus it just makes the car worth more to have an original radio intstead of aftermarket . You can learn more about what we do here.. http://wardsclassiccarradiorepair.com/id17.htmlAlmost half our business now is conversions, and the other half is servicing / restoring back to original specs. Greg
[Re: mopars4ever]
#1859505
06/29/15 09:33 AM
06/29/15 09:33 AM
Posts: 2,311 NJ, USA
bill440rt
NJ, USA
I went with one of those, also. http://www.casmfg.com/Secretaudio.htmI liked the flexibility of it vs converting the stock radio to modern internals. The converted original radio still wouldn't have worked with the planned amps, subs, etc in my car. The SST setup has mp3 & iPod jacks, CD changer, & Sirius. Can hook up external power amps. The receiver can be hidden anywhere, and the faceplate is low profile so you can hide it easily. They say you can put it recessed in your sunvisor. I hid mine inside the console. Comes with a small bracket in case you want to mount it under the dash. Stock AM thumbwheel dummy radio is in the dash. Comes with a small remote, too. I have a stock AM radio/modern conversion in another car. Nothing elaborate. Dual voice speaker in the front with 6x9's out back. Conversion was performed by this company: http://www.garytayman.com/
[Re: 440farmer]
#1859849
06/29/15 06:35 PM
06/29/15 06:35 PM
BigMoneyLewis
Alabama
Hello BigmoneyLewis How is the radio controlled after a conversion? how's the channels changed? can you use x fm satilite radio? Didn't see on the web site where it explained this?? Your radio will work exactly as it does now . The five pushbuttons will work , the tuner knob changes the stations exactly as it does on your stock radio .On off vol, tone control all will work as factory . When you turn the radio on you are in FM stero , to switch to AM simply turn the radio off and back on . To play an aux device, simply plug it in and it will play .. unplug it and it goes back to FM stereo . You can listen to satellite radio as well . And we can throw in blue tooth for an additional $ 25 . The radio I shown is a '67 GTX , but we do most all A B E body as well as most Ford and GM 1960-1974 . Greg
[Re: ProSport]
#1867646
07/10/15 11:32 AM
07/10/15 11:32 AM
ProSport
Akron, Ohio
I went with an affordable Kenwood KDC152 receiver, 3 way kenwood 6x9s in the rear package tray, and 4" 3 way kenwood speakers for the dash. I still have to decide where to mount the receiver, glove compartment seems awkward to me, even though it has a remote.
If this setup isn't quite enough I might add some 3 way 6" round kenwoods in the plastic kick panels by branching off the dash speaker wires, would that cause any problems?
[Re: ProSport]
#1871572
07/16/15 02:25 PM
07/16/15 02:25 PM
ProSport
Akron, Ohio
Must not be too many stereo guys here.
