What would cause my converter bolts to keep loosening #1857543
06/26/15 06:14 PM
06/26/15 06:14 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Never had this happen before.
Red loctite, new Flexplates, new ARP converter bolts and after 3 passes, they are loose again.
I whacked the hell out of them with a sledge hammer with a 3/4" 12 point wrench like I always have done and never had an issue before.
What could be the problem?
Maybe I need to send the converter back to change the pads on the converter.
It's a turbo action 8"
Re: What would cause my converter bolts to keep loosening [Re: Sammy] #1857550
06/26/15 06:25 PM
06/26/15 06:25 PM
Long Island, NY
B1Johnny Offline
B1Johnny  Offline
Long Island, NY
I had a bad fluid dapner ,it was cracked and was leaking the viscous fluid out of it. the bolts would come loose after two passes.it wound up cracking my crank ,it started wiping out the thrust bg.i changed the crank and put a ati dapner on it no more problems.good luck.
Re: What would cause my converter bolts to keep loosening [Re: Sammy] #1857552
06/26/15 06:26 PM
06/26/15 06:26 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Harmonics or vibration come to mind.......
Re: What would cause my converter bolts to keep loosening [Re: Sammy] #1857557
06/26/15 06:28 PM
06/26/15 06:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Conv or the engine out of balance... did you degree the trans
wave
Re: What would cause my converter bolts to keep loosening [Re: B1Johnny] #1857575
06/26/15 06:55 PM
06/26/15 06:55 PM
Washington
madscientist Offline
Washington
Just for posterity, what made the FD crack and where was the crack.
Cartainly balance issues can make converter bolts come loose. I have also seen detonation do it, and pushrods that were flexing did it, but when the pushrod issue was going on, the adjusters wouldn't stay tight either. That one was a bummer to track down.
Re: What would cause my converter bolts to keep loosening [Re: madscientist] #1857580
06/26/15 07:02 PM
06/26/15 07:02 PM
Long Island, NY
B1Johnny Offline
B1Johnny  Offline
Long Island, NY
I had a alternator on it it cracked where the pulley was bolted to the crank never saw it till I took the pulley off.
Re: What would cause my converter bolts to keep loosening [Re: Sammy] #1857682
06/26/15 08:56 PM
06/26/15 08:56 PM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
shock shock puke LOL!!!
SS/DA 1924
Re: What would cause my converter bolts to keep loosening [Re: SSDAcuda] #1857687
06/26/15 09:10 PM
06/26/15 09:10 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Detonation. Harmonics caused by detonation or anything else.
Re: What would cause my converter bolts to keep loosening [Re: camastomcat] #1857784
06/26/15 11:42 PM
06/26/15 11:42 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
I like that answer best...ole Tom has a few words of wisdom every once in a while!!
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: What would cause my converter bolts to keep loosening [Re: Sammy] #1857812
06/27/15 12:17 AM
06/27/15 12:17 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
We went through this on a short block that was supposed to be balanced. No noticeable vibration and the engine ran great. Brought the rotating assembly to a more reputable shop and it was quite a bit out of balance (don't remember the amount, but it was significant according to the machinist). After it was rebalanced, the problem went away. That is the only thing we changed.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: What would cause my converter bolts to keep loosening [Re: Dads426] #1858054
06/27/15 11:38 AM
06/27/15 11:38 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
This is what I am thinking it is too.
Going to check the ATI balancer today and see if its tight and if theres any cracks in it.
I remember it was tough getting it off last year before the rebuild. Hope I didn't hurt it fighting it off the crank.
Re: What would cause my converter bolts to keep loosening [Re: Sammy] #1858086
06/27/15 12:39 PM
06/27/15 12:39 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Do you balance your slicks or are you one of these guys that say it isn't necessarily? How's your pinion angle and what is the run-out of your driveshaft?
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: What would cause my converter bolts to keep loosening [Re: Sammy] #1858312
06/27/15 06:39 PM
06/27/15 06:39 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Had a 727 input shaft with a slight bend do that till we found it!
Re: What would cause my converter bolts to keep loosening [Re: Sammy] #1858838
06/28/15 01:20 PM
06/28/15 01:20 PM
cleveland ohio
MartyQ Offline
MartyQ  Offline
cleveland ohio
We had the same problem . New build and 1st time ever using a trans brake. Was leaving off the brake in the low 3000 range and the bolts would come loose . Stepped it up to 4800 no problems again .
Re: What would cause my converter bolts to keep loosening [Re: Sammy] #1858893
06/28/15 02:32 PM
06/28/15 02:32 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
AJ and I discovered a problem with the full round B&M flexplates that cause the bolts to come loose.The flexplate does not tighten up flush with the converter pads it contacts the inside edge of the pads or lugs and the bolts no matter how tight will not conform the plate to the pads,the bolt as well as the pads only make contact on the inner edge.We checked the pads and they are flat with the converter and starter ring.The 4 leaf clover style plates have enough flex to set flat on the pads when tightened.Look at you plate to see if it contacts the entire pad.
