Re: What would cause my converter bolts to keep loosening
[Re: Sammy]
#1857552
06/26/15 06:26 PM
06/26/15 06:26 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Never had this happen before. Red loctite, new Flexplates, new ARP converter bolts and after 3 passes, they are loose again. I whacked the hell out of them with a sledge hammer with a 3/4" 12 point wrench like I always have done and never had an issue before. What could be the problem? Maybe I need to send the converter back to change the pads on the converter. It's a turbo action 8" Harmonics or vibration come to mind.......
[Re: B1Johnny]
#1857575
06/26/15 06:55 PM
06/26/15 06:55 PM
Posts: 4,457 Washington
madscientist
Washington
I had a bad fluid dapner ,it was cracked and was leaking the viscous fluid out of it. the bolts would come loose after two passes.it wound up cracking my crank ,it started wiping out the thrust bg.i changed the crank and put a ati dapner on it no more problems.good luck. Just for posterity, what made the FD crack and where was the crack. Cartainly balance issues can make converter bolts come loose. I have also seen detonation do it, and pushrods that were flexing did it, but when the pushrod issue was going on, the adjusters wouldn't stay tight either. That one was a bummer to track down.
[Re: camastomcat]
#1857784
06/26/15 11:42 PM
06/26/15 11:42 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Detonation. Harmonics caused by detonation or anything else. I like that answer best...ole Tom has a few words of wisdom every once in a while!!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: Sammy]
#1857812
06/27/15 12:17 AM
06/27/15 12:17 AM
Posts: 1,443 Maryland
Dads426
Maryland
We went through this on a short block that was supposed to be balanced. No noticeable vibration and the engine ran great. Brought the rotating assembly to a more reputable shop and it was quite a bit out of balance (don't remember the amount, but it was significant according to the machinist). After it was rebalanced, the problem went away. That is the only thing we changed.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Dads426]
#1858054
06/27/15 11:38 AM
06/27/15 11:38 AM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
We went through this on a short block that was supposed to be balanced. No noticeable vibration and the engine ran great. Brought the rotating assembly to a more reputable shop and it was quite a bit out of balance (don't remember the amount, but it was significant according to the machinist). After it was rebalanced, the problem went away. That is the only thing we changed. This is what I am thinking it is too. Going to check the ATI balancer today and see if its tight and if theres any cracks in it. I remember it was tough getting it off last year before the rebuild. Hope I didn't hurt it fighting it off the crank.
[Re: Sammy]
#1858086
06/27/15 12:39 PM
06/27/15 12:39 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Do you balance your slicks or are you one of these guys that say it isn't necessarily? How's your pinion angle and what is the run-out of your driveshaft?
