Page 6 of 10 1 2 4 5 6 7 8 9 10
Re: MUSCLE MOTORS 30 MIN ENGINE [Re: steve660] #1857236
06/26/15 03:35 AM
06/26/15 03:35 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Originally Posted By steve660
Originally Posted By MuscleMike
All I want is for Mr. Edwards to be enjoying his car. That being said, you don't buy something from Home Depot, have an issue and take it to Lowes to have it fixed and send Home Depot the bill. Obviously We are under a micro scope and it is in our best interest to bring this situation to a speedy conclusion. For the record: I, Michael Ware, owner of Muscle Motors will bring the engine back here, replace the bent valve, verify and adjust guide clearance if necessary.
I suspect that the lifters may have excessive clearance causieng the low oil pressure at idle. We will completely disassemble the engine and using a BHJ fixture install lifter bushings and hone for correct sizing again no charge. Mr Edwards also wanted a different type of retainer, We will change those at no cost to Mr Edwards. We will then have the engine shipped back to Mr Edwards and we will absorb the shipping charges. I believe this a fair and amicable offer.
Mike, Im very apprehensive about this but I will give your offer some thought. If you bush lifter bores it will also require diff pushrods without restricters. I would also like to know how you will address the low cylinder pressure issue. My thinking is to spec out a custom cam. I've used Scott Brown before and know he's really good at pump gas cams.
Then you're continuing to be part of the problem, not the solution. The owner of the shop has agreed to fix the issues at his cost, and I'm sorry...but it doesn't get any better than that. Guess what? EVERY engine builder has had something not turn out they way they wanted. It take a true, dedicated business man to stand behind his build which is appears what's going on here. Put your man-pants on and WORK WITH THE OFFER TO FIND THE SOLUTION. Better than bashing a well established shop who HAS OFFERED TO FIX IT.
PS: Being that you're NOT an engine builder why do you care about cylinder pressure as long as it's a solid motor and makes the power?? Sounds like you're continuing to LOOK FOR "issues". If "your thinking is to spec a custom cam", then maybe you should have "been thinking" to build it yourself. Right?
Re: MUSCLE MOTORS 30 MIN ENGINE [Re: cudadoug] #1857271
06/26/15 09:30 AM
06/26/15 09:30 AM
australia
charger410 Offline
charger410  Offline
australia
I agree
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
Re: MUSCLE MOTORS 30 MIN ENGINE [Re: charger410] #1857284
06/26/15 10:13 AM
06/26/15 10:13 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
If I were steve660, I'd bring this public discussion to a close, and deal with MM on a one to one basis. There's nothing more to be gained by playing out this saga publicly.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: MUSCLE MOTORS 30 MIN ENGINE [Re: DusterDave] #1857292
06/26/15 10:39 AM
06/26/15 10:39 AM
gregsdart Offline
gregsdart  Offline
I originally posted to send it to Best or another Mopar shop, but after reading Mikes response you have to give him a chance to fix it. This is his bread and butter hear, not some used car deal that went sour. Also diagnosing what is wrong with a big project like this isn't easy. There may be many things a novice misses that an experienced engine builder would know. As far as the time line, a custom engine is always going to be hard to deliver on time, and almost never on budget. OP, good luck with this deal, and I hope it turns out the best for both.
Re: MUSCLE MOTORS 30 MIN ENGINE [Re: steve660] #1857300
06/26/15 10:52 AM
06/26/15 10:52 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
You have nothing to lose in sending it back at this point. The laundry has been aired and if the results aren't right everyone will know. I'm sure Mike will take extra care to make sure it goes out right this time. If it does'nt it's obvious to him he will lose some future business.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: MUSCLE MOTORS 30 MIN ENGINE [Re: Eric] #1857314
06/26/15 11:17 AM
06/26/15 11:17 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I agree 100%. He threw a very nice offer out there in writing for all to see. Go for it.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: MUSCLE MOTORS 30 MIN ENGINE [Re: pittsburghracer] #1857380
06/26/15 01:23 PM
06/26/15 01:23 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
iagree There's not too many shops in this day and age who will make the offer that's been given.
It's ultimately your decision alone...but I personally have never thought that "burning bridges" is a good message to send to the next shop you may want to work with... twocents
...FAFO...
Re: MUSCLE MOTORS 30 MIN ENGINE [Re: pittsburghracer] #1857384
06/26/15 01:30 PM
06/26/15 01:30 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
I will give MM the opportunity to make things right. Once I get it back I will let everyone know the results.
As far as the comments regarding cylinder pressure goes, Mike is the one that told me that 150 was lower than what he anticipated. That's why I mentioned it.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: MUSCLE MOTORS 30 MIN ENGINE [Re: steve660] #1857385
06/26/15 01:34 PM
06/26/15 01:34 PM
Washington
madscientist Offline
Washington
Good decision on your part. Give them the same shot you would expect if you made a mistake.
BTW...did MM provide a build sheet with the engine? If so, it would have all the measurements and dimensions on it.
Just curious.
Re: MUSCLE MOTORS 30 MIN ENGINE [Re: madscientist] #1857438
06/26/15 03:15 PM
06/26/15 03:15 PM
fullmetaljacket Offline
Mazel-Tov.
Re: MUSCLE MOTORS 30 MIN ENGINE [Re: madscientist] #1857440
06/26/15 03:18 PM
06/26/15 03:18 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
Just curious.
PM SENT......
Re: MUSCLE MOTORS 30 MIN ENGINE [Re: madscientist] #1857619
06/26/15 07:53 PM
06/26/15 07:53 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Just curious.
that depends on how long he takes to get his motor back to him and if he tries any additional charges and how well he takes care of the issues. this could turn into another motor prison...
Re: MUSCLE MOTORS 30 MIN ENGINE [Re: Quicktree] #1857688
06/26/15 09:13 PM
06/26/15 09:13 PM
dogdays Offline
dogdays  Offline
The problem with the Internet.....things get blown way out of proportion and the bandwagon effect gets into full swing. If you're in this hobby, you have to be prepared for some disappointment. Not everything will turn out the way you dream it will. No-one put a gun to your head and made you spend that money.
Bystanders should realize that whoever is complaining will put things in the most favorable light for himself.
Reality bites, and it is sickening to see an offer that is IMHO way more than fair, an offer that will cost the business owner a sizeable amount of change, pi$$ed and moaned about and second-guessed every way from Sunday.
There's fair, and there's "my idea of fair".
After all this amount of crap being slung, I can't see any reputable engine builder taking on a new job from the OP. Life is too short.
Or maybe I'm just tired and grumpy after a week of work.
R.
Re: MUSCLE MOTORS 30 MIN ENGINE [Re: steve660] #1858034
06/27/15 10:53 AM
06/27/15 10:53 AM
New York
polyspheric Offline
polyspheric  Offline
New York
A 12:1 motor with good ring seal needs the intake closing way up in the 80's ABDC to show 150 psi on a gauge,
Does it?
Boffin Emeritus
Re: MUSCLE MOTORS 30 MIN ENGINE [Re: polyspheric] #1858101
06/27/15 01:00 PM
06/27/15 01:00 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
quote=polyspheric]A 12:1 motor with good ring seal needs the intake closing way up in the 80's ABDC to show 150 psi on a gauge,
Does it? [/quote]
Cam card shows:
IO @ 31.5
IC@ 71.5
EO@ 85.5
EC@ 29.5
Re: MUSCLE MOTORS 30 MIN ENGINE [Re: steve660] #1858153
06/27/15 02:23 PM
06/27/15 02:23 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Is that at .050?
Is it installed that was or advanced or retarded?
Re: MUSCLE MOTORS 30 MIN ENGINE [Re: steve660] #1858193
06/27/15 03:19 PM
06/27/15 03:19 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
Sounds like the making of a happy ending
Re: MUSCLE MOTORS 30 MIN ENGINE [Re: HotRodDave] #1858201
06/27/15 03:28 PM
06/27/15 03:28 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
Originally Posted By HotRodDave
Is that at .050?
Yes, That's at .050. I'm not sure how MM installed it. I was going to check how it was installed and If it was installed straight up I was going to try advancing it to increase cylinder pressure. I will be pulling engine next week and get it ready to return to MM.
Re: MUSCLE MOTORS 30 MIN ENGINE [Re: steve660] #1858317
06/27/15 07:13 PM
06/27/15 07:13 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Is that at .050?
If your correct on your specs your @ 4* advanced installed at a 110 ICL with a 114 LSA cam with a intake duration of 283 @ .050 and a exhaust duration of 295 @ .050
Re: MUSCLE MOTORS 30 MIN ENGINE [Re: steve660] #1858322
06/27/15 07:29 PM
06/27/15 07:29 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
Do understand scary position, been there with a fellow member who passed away with my cash, went to another shop "Palm beach motors" screwed again, spent/lost. 20 grand just to get a stroker motor done, big boy pants lighted up be cash deposit I lost at both shops and they had good reputation. But seems you need to let MM make it right my2 cents good luck
