Re: Rough running issues on a 318 2 bbl [Re: Mopar Boy] #1160149
02/03/12 12:01 PM
02/03/12 12:01 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I don't know if this was mentioned but the bbd 2 bbls had a habit of warping. Might be getting a mild vacuum leak, the fix is check the mating surfaces if you find the top or base plate is warped you can heat it in an oven and then straighten it out on a known flat surface. Might need a tad bit of file work but be careful.
I always liked those carbs and still have several. Very easy to rebuild and they work fine for thier intended purpose. The 4 bbl will porbably make you happier once dialed in. Of course this might lead to a whole other can of worms, finding kick down linkage and such.
Still think a 318 in a Chrysler is weird, but I am sure they pulled the big block and still wanted to sell the car. Porbably had the 318 laying around. Glad it turned into a good deal for ya
I have mechanical Aptitude.
I can screw up anything.
Re: Rough running issues on a 318 2 bbl [Re: Mopar Boy] #1857158
06/25/15 11:45 PM
06/25/15 11:45 PM
St. Louis, MO
BevoHoosier Offline
BevoHoosier  Offline
St. Louis, MO
bumping this old thread, thanks for the info. Having trouble with my 383- 2bbl bbd carter... has run fine for many years, but since getting out of storage this year, have had dying at idle after warming up, then fuel leaking from somewhere out of the carb onto the intake manifold & boiling...
I have tried tightening the mounting flange nuts, hopefully that's it. Will try it again once it cools down... I wonder also if it's leaking out of the butterfly linkage rod
I have rebuilt this carb once before years ago, and like i said, ran great... but i don't remember if the rebuild will help eliminate a leak at the linkage rod?????
thanks
BMW 67 Dodge Polara 383
Re: Rough running issues on a 318 2 bbl [Re: Mopar Boy] #1857159
06/25/15 11:52 PM
06/25/15 11:52 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Sounds like your float quit floating.
Don't be the exception.
