Re: BB hyd roller performance?
[Re: AndyF]
#185693
01/06/09 08:06 PM
01/06/09 08:06 PM
Posts: 5,080 organ
maximum entropy
organ
brace yourself- they're really expensive. i'm sure they're worth every penny, though.
[Re: maximum entropy]
#185694
01/06/09 09:37 PM
01/06/09 09:37 PM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
I don't know who grinds them for Hughes but they are the most serious ramps I've seen cut for any Hydraulic roller.....they're almost square and they're on a pretty small base circle...in fact when I looked at it I said "no way the lifter will ride this without collapsing the hydraulic plunger"....7200 RPM later I have to say that for my motor I give very little away to a solid roller (except lift maxes out around .600) and with the Chaps flowing more at .500 than most heads flow at .650 it's a perfect fit for my mostly street car. In fact most people don't believe it's a hydraulic at all...they shake their heads and say "no way a juicer rev's that quick".
I was all set to buy a solid until I saw these, yeah they cost but they work and I figured since i already had the Hydraulic lifters overall I still came out ahead...as long as they deliver...I feel like they do IN SPADES!!
[Re: AndyF]
#185698
01/07/09 02:39 AM
01/07/09 02:39 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Sounds like a good combo, I'll be interested to hear how it works out.
Well...that's a deep subject!! This is the guy that wanted lots of TQ, and driveability and he also wanted to make it look very stock. He supplied me with a stock type oil pan and I told him I didn't think it would work. I was afraid the oil would get sucked up around the crank at higher rpms. Well looks like I need to insist that either my customers listen to me or they pay...$$$! I made 2 short pulls from 3000-4000rpm and everything looked good. 603ft.lbs. at 4000 rpm!! So off to 5000 rpm we go, and just above 4200rpm, the oil pressure started to drop. So I aborted the pull and called him so he could now order the right shi-stuff and be done. Lesson learned for me...again. But it looks like it'll clear 520HP so that is nice! I won't have any more info for at least a week, but 600+ TQ with 9.8:1, mild ported Source heads and that custom hyd. roller cam. And this thing revs as quick as my 360 did!! It sounds very healthy. This was with our cheap dyno/hooker 1 7/8 headers given to us by a friend of mine. And the carb was still rich, and we hadn't even tried any timing adjustments. So there's more to come.
I will post results when we have them, and hopefully a video as well. I'm happy with the XFI lobes so far!
Brian
[Re: Streetwize]
#185700
01/07/09 11:00 AM
01/07/09 11:00 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
They appear to be Bullet grinds. At least comparing the numbers they look to be the same as the Bullet CRA hyd roller grinds.
http://bulletcams.com/Masters/HRlobes.htm
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Cab_Burge]
#185704
01/08/09 11:51 AM
01/08/09 11:51 AM
Posts: 383 Essex, Ont., Canada
Fishmarket
Essex, Ont., Canada
How do the XFI lobes compare to the XE lobes?
1972 Plymouth Cuda 340 4 speed
1971 Plymouth Road Runner 383 Auto
1970 Plymouth Duster /6 Auto
[Re: Cab_Burge]
#185705
01/08/09 01:48 PM
01/08/09 01:48 PM
Posts: 3,076 Renton, Wa.
Classof70Chally
super gas
super gas
Renton, Wa.
Kelob....IIRC my springs are right in the same range as yours and they were also from Scott, same ones I ran on my 508 252/258 roller that was in the car before the new motor.
I was told by Comp Cams to not run more than 400 lbs open on thier hydraulic roller lifters I set the seat pressure right at 200 lbs which made 395 to 405 lbs open, I hope they don't find out I cheated by 5 lbs open That was on a new 426 Street Hemi World block street motor, it seems to rev good and no valve float yet up to 6500 rpm, where the owner wants to shift it at
Interesting info from Comp Cams about the open pressure. Looks like I'll just make it as the open pressure on my set up will be 375 lbs.
[Re: AndyF]
#185707
01/08/09 09:56 PM
01/08/09 09:56 PM
Streetwize
Weddington, N.C.
Cab, Interestingly Scott Brown specifies Crane lifters (not Comp) and runs higher (maybe 50 pounds over the nose)spring pressures, apparently it's the lifters and noty the cam itself that are the limitation All I know is this combination revs to 7K with Ti Retainers and 11/32 stem long valvess and pretty spot on geometry...and it doesn't seem to give up much of anything to comparable solid rollers I've run.
