Proform Street carb ? #1852488
06/19/15 01:42 PM
06/19/15 01:42 PM
A Banana Republic near you.
JohnRR Offline OP
JohnRR  Offline OP
I'm going to get my Dart running again and I don't want to deal with fuel boiling issues with the stock Carter.
Are they any good?
Re: Proform Street carb ? [Re: JohnRR] #1852495
06/19/15 01:53 PM
06/19/15 01:53 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The few I`ve done need work and a good CLEAN calibration and every hole needs to be pin viced to make sure they`re drilled all of the way through
as some are not.......
Re: Proform Street carb ? [Re: JohnRR] #1852501
06/19/15 02:05 PM
06/19/15 02:05 PM
JohnRR Offline OP
JohnRR  Offline OP
Thanks , I guess I'll pass on it.
I can get one new for 280 bucks but if I have to have it gone thru just so it works well I might as well look for a good used holley.
Re: Proform Street carb ? [Re: JohnRR] #1852654
06/19/15 05:28 PM
06/19/15 05:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`d get it at that price and try to not even work on old holleys since billet surpasses em in every way.......
Re: Proform Street carb ? [Re: JohnRR] #1856125
06/24/15 07:44 PM
06/24/15 07:44 PM
MassHole Central
rtman Offline
rtman  Offline
MassHole Central
I may have a good used Holley for you, John, in a few weeks. Too long of a story here. I'll know shortly if I'm staying with the Holley or going back to Carter. Holley 750cfm w/vacuum secondaries.
Re: Proform Street carb ? [Re: JohnRR] #1856450
06/25/15 09:31 AM
06/25/15 09:31 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I built a Pro-Form carb. I started with a 750DP, added the main body, liked it ran great, added the base plate soon after, Worked very well. Pretty much the only thing left from the Holley was the fuel bowls. If you are having boiling issues get the carb up off the intake. Use a 1/2" 4 hole spacer.
Re: Proform Street carb ? [Re: rtman] #1856604
06/25/15 01:29 PM
06/25/15 01:29 PM
JohnRR Offline OP
JohnRR  Offline OP
I have one of those , but thanks anyways ...
Re: Proform Street carb ? [Re: Mr.Yuck] #1856606
06/25/15 01:31 PM
06/25/15 01:31 PM
JohnRR Offline OP
JohnRR  Offline OP
Trying to head off a potential issue that seems to be a reoccurring theme with Carter type carbs, and do it as cheaply as possible because I'll be sending the carb down the road eventually. .
