Re: Proform Street carb ?
[Re: JohnRR]
#1852495
06/19/15 01:53 PM
06/19/15 01:53 PM
Thumperdart
State of confusion
The few I`ve done need work and a good CLEAN calibration and every hole needs to be pin viced to make sure they`re drilled all of the way through as some are not.......
[Re: JohnRR]
#1852501
06/19/15 02:05 PM
06/19/15 02:05 PM
Posts: 75,051 U.S.S.A.
JohnRR
U.S.S.A.
Thanks , I guess I'll pass on it.
I can get one new for 280 bucks but if I have to have it gone thru just so it works well I might as well look for a good used holley.
[Re: JohnRR]
#1852654
06/19/15 05:28 PM
06/19/15 05:28 PM
Thumperdart
State of confusion
I`d get it at that price and try to not even work on old holleys since billet surpasses em in every way.......
[Re: rtman]
#1856604
06/25/15 01:29 PM
06/25/15 01:29 PM
JohnRR
U.S.S.A.
I may have a good used Holley for you, John, in a few weeks. Too long of a story here. I'll know shortly if I'm staying with the Holley or going back to Carter. Holley 750cfm w/vacuum secondaries. I have one of those , but thanks anyways ...
[Re: Mr.Yuck]
#1856606
06/25/15 01:31 PM
06/25/15 01:31 PM
JohnRR
U.S.S.A.
I built a Pro-Form carb. I started with a 750DP, added the main body, liked it ran great, added the base plate soon after, Worked very well. Pretty much the only thing left from the Holley was the fuel bowls. If you are having boiling issues get the carb up off the intake. Use a 1/2" 4 hole spacer. Trying to head off a potential issue that seems to be a reoccurring theme with Carter type carbs, and do it as cheaply as possible because I'll be sending the carb down the road eventually. .
