A body Fuel Sending unit removal question #185567
01/06/09 12:28 PM
01/06/09 12:28 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
Its been awhile since I removed a sending unit from an A body. Does the tank need to be lowered or dropped to allow removal of the sending unit? Or can I just pull it out as it sits? The vehicle in question is a 72 Dart.I want to remove the sender to check for a sunk float.
I suppose it wouldnt hurt to raise the rear end and support the frame on jackstands to allow the rearend to hang,allowing some clearance?
Re: A body Fuel Sending unit removal question [Re: SPWC] #185568
01/06/09 12:33 PM
01/06/09 12:33 PM
okla.
O
okie Offline
okie  Offline
O
okla.
Just raise it up, you don't have to remove the tank. Good Luck! Ronnie in Okla.
Re: A body Fuel Sending unit removal question [Re: SPWC] #185569
01/06/09 12:34 PM
01/06/09 12:34 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
works every time
Re: A body Fuel Sending unit removal question [Re: gtx6970] #185570
01/06/09 08:26 PM
01/06/09 08:26 PM
Lyons, CO
MileHighDart Offline
Lyons, CO
works every time
Re: A body Fuel Sending unit removal question [Re: MileHighDart] #185571
01/06/09 08:31 PM
01/06/09 08:31 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
On an abody, just pull the sending unit... on my '73 ebody not so lucky... it is in the way of the exhaust...
Re: A body Fuel Sending unit removal question [Re: 6T6Cuda] #185572
01/06/09 09:41 PM
01/06/09 09:41 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
One of these makes the job a lot easier:
http://www.quantaproducts.com/prodinfo.asp?number=C-LRW
Re: A body Fuel Sending unit removal question [Re: 69Cuda340S] #185573
01/06/09 09:56 PM
01/06/09 09:56 PM
SPWC Offline OP
SPWC  Offline OP
I did the job today,I used a Brass Drift and hammer and lightly tapped the ring loose. Installation was easier ,I installed a new gasket and the locking ring pretty much screwed right into place with a little tension.
