Re: Starter clearance for Mega Block w/ reactor
[Re: indcontrols]
#1854457
06/22/15 05:14 PM
06/22/15 05:14 PM
Posts: 289 Lowes
steve660
Lowes
Same problem here. Had to grind the block, sanded the nut that attaches the bracket to the stud to make it thinner, shorten the copper stud and rebent the bracket that attaches to the stud.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: indcontrols]
#1854463
06/22/15 05:20 PM
06/22/15 05:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
There is a guy on the board here that makes a high output starter that should work... his name is Rob Mccord or something like that... maybe someone else will remember his name.. its a clockable starter
[Re: MR_P_BODY]
#1854608
06/22/15 07:31 PM
06/22/15 07:31 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
There is a guy on the board here that makes a high output starter that should work... his name is Rob Mccord or something like that... maybe someone else will remember his name.. its a clockable starter http://www.robbmcperformance.com/products/mopar_starter.htmlI think this is who you were referring to Mr P. I have looked at these , but I have not used one.
"Just a Bracket car dressed up like a streetcar"
[Re: Just-a-dart]
#1854705
06/22/15 09:07 PM
06/22/15 09:07 PM
MR_P_BODY
There is a guy on the board here that makes a high output starter that should work... his name is Rob Mccord or something like that... maybe someone else will remember his name.. its a clockable starter http://www.robbmcperformance.com/products/mopar_starter.htmlI think this is who you were referring to Mr P. I have looked at these , but I have not used one. Yep.. thats the one.. thanks
[Re: indcontrols]
#1855437
06/23/15 07:41 PM
06/23/15 07:41 PM
Posts: 197 Milwaukee, WI
moparjimbo
Milwaukee, WI
I have that Mc Robb one since I needed no offset to the starter motor to clear my headers, and I have his starter on another 505 Wedge engine I have and liked it a lot. It required grinding of the block in the circular area around it to get it in there.
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire 1973 Challenger - 572 Indy Hemi 860HP 1975 Trailduster Convertible, 440 1967 Plymouth Fury Police Pursuit 2DR 505 Stroker 2004 Neon SRT4 modded www.milwaukeemopar.com
