Starter clearance for Mega Block w/ reactor #1854403
06/22/15 04:21 PM
06/22/15 04:21 PM
South Florida
indcontrols Offline OP
South Florida
Well, I tried yesterday to mount my mini starter (actually two of them) to my Mega Block and found that the inside bolt for the solenoid hits the carve out area in the block, preventing the starter from mounting straight.
I pulled out a spare (Summit starter - new), and had the same issue with that one. Ended up having to put in a big ole stock mopar starter - fits fine, but is struggling mightily...
I remember having to space the starter way back when using the Reactor flexplate, but I don't remember having the clearance issue.
Anyone run across this before ?? Is there a race starter that will fit ? I don't think the factory Mopar one is long for this world at 14:1 !!!
Re: Starter clearance for Mega Block w/ reactor [Re: indcontrols] #1854404
06/22/15 04:21 PM
06/22/15 04:21 PM
South Florida
South Florida
I should have mentioned it's a JW ultrabell and a glide...
Re: Starter clearance for Mega Block w/ reactor [Re: indcontrols] #1854428
06/22/15 04:43 PM
06/22/15 04:43 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I can't speak to your exact combination of parts.........but I know on the mega-Block motor that I had, it took a LOT of grinding to make a Tilton starter work
Re: Starter clearance for Mega Block w/ reactor [Re: indcontrols] #1854451
06/22/15 05:04 PM
06/22/15 05:04 PM
South Florida
South Florida
That's what I was afraid of...
Re: Starter clearance for Mega Block w/ reactor [Re: indcontrols] #1854457
06/22/15 05:14 PM
06/22/15 05:14 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
Same problem here. Had to grind the block, sanded the nut that attaches the bracket to the stud to make it thinner, shorten the copper stud and rebent the bracket that attaches to the stud.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: Starter clearance for Mega Block w/ reactor [Re: indcontrols] #1854463
06/22/15 05:20 PM
06/22/15 05:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
There is a guy on the board here that makes a high output
starter that should work... his name is Rob Mccord or something
like that... maybe someone else will remember his name.. its a
clockable starter
wave
Re: Starter clearance for Mega Block w/ reactor [Re: indcontrols] #1854478
06/22/15 05:29 PM
06/22/15 05:29 PM
South Florida
South Florida
Sounds like that would be the hot ticket.
Re: Starter clearance for Mega Block w/ reactor [Re: indcontrols] #1854519
06/22/15 06:27 PM
06/22/15 06:27 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
I had no issue putting my little starter on my mega block, but it has a 727.
Re: Starter clearance for Mega Block w/ reactor [Re: MR_P_BODY] #1854608
06/22/15 07:31 PM
06/22/15 07:31 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
clockable starter
wave
http://www.robbmcperformance.com/products/mopar_starter.html
I think this is who you were referring to Mr P. I have looked at these , but I have not used one.
"Just a Bracket car dressed up like a streetcar"
Re: Starter clearance for Mega Block w/ reactor [Re: Just-a-dart] #1854705
06/22/15 09:07 PM
06/22/15 09:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
clockable starter
wave
Yep.. thats the one.. thanks
wave
Re: Starter clearance for Mega Block w/ reactor [Re: indcontrols] #1854769
06/22/15 10:22 PM
06/22/15 10:22 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
If you have room in front of your driver side header, get the Meziere starter. You can clock it and it spins over like no other.
I just bought one for the first time 2 weeks ago after I got my headers done.
Re: Starter clearance for Mega Block w/ reactor [Re: indcontrols] #1855040
06/23/15 10:23 AM
06/23/15 10:23 AM
South Florida
South Florida
Wow - That Meziere is pricey !! Think that's what I'll do though. It looks like that's the way to kill this problem, on to the next one. !
Thanks !
Re: Starter clearance for Mega Block w/ reactor [Re: indcontrols] #1855437
06/23/15 07:41 PM
06/23/15 07:41 PM
Milwaukee, WI
moparjimbo Offline
moparjimbo  Offline
Milwaukee, WI
I have that Mc Robb one since I needed no offset to the starter motor to clear my headers, and I have his starter on another 505 Wedge engine I have and liked it a lot. It required grinding of the block in the circular area around it to get it in there.
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire
1973 Challenger - 572 Indy Hemi 860HP
1975 Trailduster Convertible, 440
1967 Plymouth Fury Police Pursuit 2DR 505 Stroker
2004 Neon SRT4 modded
www.milwaukeemopar.com
