71 RT charger #1853671
06/21/15 09:38 AM
06/21/15 09:38 AM
New Jersey
FC7 cuda Offline OP
FC7 cuda  Offline OP
New Jersey
Trying to work the bugs out of my RT .. when I pull off the fuel sending unit wire and ground it the gauge only reads half way I thought it supposed to go to full? Does this mean bad gauge?
Re: 71 RT charger [Re: FC7 cuda] #1854104
06/22/15 12:53 AM
06/22/15 12:53 AM
Rustylvania
Mr_fixit Offline
Mr_fixit  Offline
Rustylvania
Could be, or the voltage limiter could be the problem. Do the other gauges that are controlled by the limiter read lower than they should?
