changing motor mounts #1852470
06/19/15 12:50 PM
06/19/15 12:50 PM
Kenosha, Wi
GOLDMYN Offline OP
GOLDMYN  Offline OP
Kenosha, Wi
Hi, I'm going to change my old rubber motor mount on the left side to solid on my 1971 Charger w/440. PS w/AC. Any helpful suggestion? Thanks
Semper Fi
Re: changing motor mounts [Re: GOLDMYN] #1852472
06/19/15 12:52 PM
06/19/15 12:52 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I used the Moroso steel mount on the drivers side in my Satellite. Fit perfectly, swap was a 15-minute job. Hardest part is supporting the engine while you make the swap.
Re: changing motor mounts [Re: GOLDMYN] #1852473
06/19/15 01:02 PM
06/19/15 01:02 PM
Kenosha, Wi
GOLDMYN Offline OP
GOLDMYN  Offline OP
Kenosha, Wi
and how did you support the motor?, I will be laying on my back.
Semper Fi
Re: changing motor mounts [Re: GOLDMYN] #1852632
06/19/15 05:03 PM
06/19/15 05:03 PM
Good Ole USA
djw383 Offline
djw383  Offline
Good Ole USA
I suggest Schumacher Poly-Loc's, best of both worlds! And Mancini is having a sale for Fathers Day as they have posted on this site.."It’s Father’s Day weekend so Mancini Racing wants to reward all the dads out there for all you do. We know it’s tough these days being a dad so we’re rewarding everyone with a 10% discount* on all orders during starting Friday, June 19, the through midnight Sunday, June 21."
http://www.manciniracing.com/newmapopomom.html
Re: changing motor mounts [Re: GOLDMYN] #1852683
06/19/15 06:03 PM
06/19/15 06:03 PM
Puyallup, WA
Puyallup, WA
Its been a few years, abut I believe I supported the engine with my hoist from above, while I worked from beneath.
Re: changing motor mounts [Re: StealthWedge67] #1853062
06/20/15 09:31 AM
06/20/15 09:31 AM
moparx Offline
moparx  Offline
you can also use a piece of properly sized 1/2-3/4" plywood with a floor jack on the oil pan sump to support the engine while changing mounts. make safety your #1 game while under your car with properly placed stands/ramps. lost members are hard posts to read.
beer
Re: changing motor mounts [Re: moparx] #1853420
06/20/15 09:09 PM
06/20/15 09:09 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
pull engine mount bolt, place a 2x4 about 4 inches long on the oil pan rail and raise with your floor jack on the 2x4.
Re: changing motor mounts [Re: GOLDMYN] #1853496
06/20/15 10:20 PM
06/20/15 10:20 PM
Kenosha, Wi
GOLDMYN Offline OP
GOLDMYN  Offline OP
Kenosha, Wi
thanks for the tips
Semper Fi
