flathead 6 removal #1850174
06/16/15 01:29 AM
06/16/15 01:29 AM
SD
Z
zrxkawboy Offline OP
Z
SD
Getting ready to pull the 230 from my '57 Plymouth (for a rebuild). First time I've done any major work on one of these engines. Any tips or tricks specific to the flatheads? Thanks!
It's Swifty! Swifty, you toad sucker!
Re: flathead 6 removal [Re: zrxkawboy] #1850802
06/16/15 11:39 PM
06/16/15 11:39 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Only thing I can think of is to be prepared for the weight of those flathead 6s. they are much more heavy then one might expect, think Big block kind of weight!
These motors are pretty simple and very well engineered. I think, just because, I would be covering all the bolts and things you want to turn out with some penetrating oil. Gene
Re: flathead 6 removal [Re: zrxkawboy] #1851020
06/17/15 12:33 PM
06/17/15 12:33 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
One must for the old flathead, you must replace the water distribution tube in the block.
Don't be the exception.
Re: flathead 6 removal [Re: zrxkawboy] #1851354
06/17/15 09:59 PM
06/17/15 09:59 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I'd strongly suggest pulling the whole front clip (bumper first, then grille, radiator and bulkhead, fenders, etc. as one chunk). It's a lot easier than it looks, and darn near everything you touch (wiring, bolts, should be given a clean up and look anyway.
I've done this on a couple 40s cars and a mid fifties car.
You WILL need a friend to help get it off, but it sure makes stuff easier to pull.
For flatty info, the P15/D24 site is your best bet.
The Imperial club site may have some useful stuff too.
Re: flathead 6 removal [Re: RodStRace] #1851377
06/17/15 10:21 PM
06/17/15 10:21 PM
IN
ahy Offline
ahy  Offline
IN
When I pulled the flattie from a Power Wagon I pulled the whole clip like Rod suggested. Easy to do and made it much easier.
If you have a FSM it will probably have step by step... that is what I used plus an engine hoist and homemade lifting bar (4x4 with through bolt eyes basically).
Re: flathead 6 removal [Re: zrxkawboy] #1851562
06/18/15 01:46 AM
06/18/15 01:46 AM
SD
Z
Z
SD
Thanks for the replies! I started on the little things tonight, and I have a dumb question. It looks like the bellhousing surrounds the flywheel (in front). Am I seeing this right? If so, how does this affect engine removal? Please excuse me: I've rebuilt engines before, but they've all been '60s and '70s...the oldest one was my '67 Plymouth.
Re: flathead 6 removal [Re: zrxkawboy] #1851833
06/18/15 03:06 PM
06/18/15 03:06 PM
dogdays Offline
dogdays  Offline
My '64Dog Poly 318 has the bellhousing that wraps around the flywheel. I believe it's very much like yours, may even be the same. It weighs a ton, felt like 70lb to me. On my truck and I suspect on yours too, the transmission hangs out on the end of the bellhousing and doesn't have its own crossmember. I took the transmission off first and then pulled the engine complete with bellhousing. It's a bit tricky because you have to get the mounts up and over the engine mount insulator bolts, and there are two front, two back.
I instead unbolted the rear mounts from the frame.
Assembly: First I bolted on flywheel, then bellhousing. It's much more difficult to access the flywheel with the bellhousing in place. Then I mounted the transmission. That was a bad move. The transmission will not go over the rear huge crossmember, so I had to pull it all out and disconnect the transmission, which I put on the ground.
This time I got the stuff lined up and dropped the engine in, however I couldn't install the rear mounts because top of bellhousing hit the cab trans tunnel. So I picked the engine up a little and moved it forward, then installed the rear mounts onto the bellhousing. This time it went together well. I tightened all the bolts and then installed the transmission.
I am pretty sure that your bellhousing will bolt up to a 318. Everything should fit on a Poly motor, and on the LA motor there's one bolt hole that's in the wrong place at one of the lower corners. This is the bolt that holds the two together right next to a dowel. Many people just leave it out, but because where it was located I decided to have a bolt there. I marked where the matching hole was, drilled and tapped the bellhousing IIRC.
R.
Re: flathead 6 removal [Re: zrxkawboy] #1852157
06/18/15 10:27 PM
06/18/15 10:27 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It has been so long since I removed a flathead 6 (38 Plymouth) that I forget. But I had the entire front end off that vehicle so room was plentiful.
Re: flathead 6 removal [Re: zrxkawboy] #1852159
06/18/15 10:28 PM
06/18/15 10:28 PM
SD
Z
Z
SD
Thanks for the detailed reply, dogdays...it is very helpful!
Re: flathead 6 removal [Re: zrxkawboy] #1852173
06/18/15 10:42 PM
06/18/15 10:42 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I can bet cash money that a flathead 6 bell will not fit any flavor of 318.
Poly to LA, yeah, flat 6 no.
Re: flathead 6 removal [Re: Supercuda] #1852673
06/19/15 05:50 PM
06/19/15 05:50 PM
AZ
Mike P Offline
Mike P  Offline
AZ
Just my twocents pull the hood, bolt an engine leveler to the 6 and pull the engine and tranny as a unit, probably about 2 hours and you don't have a bunch of sheetmetal to worry about finding a place for (or scratch up depending on how good the paint is).
But hey what do I know.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: flathead 6 removal [Re: Mike P] #1852888
06/19/15 11:26 PM
06/19/15 11:26 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Those inner fenders on that 57 make pulling the front sheet metal off a pita for sure. That and the bumper brackets go through the front sheet metal. Without the inner fenders and the front bumpers, its like 5 bolts and the clip lifts off, with the inner fenders and the bumper, its probably 30 bolts (1/2 of which are end wrench off & tend to break). Mopar was pretty serious about that front sheet metal not falling off.
Pictures, notice how much stuff is removed from the sheet metal clip?
Gene
Re: flathead 6 removal [Re: poorboy] #1852970
06/20/15 12:53 AM
06/20/15 12:53 AM
AZ
Mike P Offline
Mike P  Offline
AZ
I should have mentioned it in my previous post, but better late than never. The best money you can spend at this point is to purchase a factory shop manual, which should answer most of your questions. There on E bag in both CD and paper form.
Dogdays did a nice writeup on his 64 truck but unfortunately his is a completely different setup than the Plymouth (which among other things does in fact have a transmission cross member). I could do a writeup on what needs to be done, but it would be from memory and rather lengthy and you will find all the info in the service manual.
Re: flathead 6 removal [Re: zrxkawboy] #1852995
06/20/15 01:33 AM
06/20/15 01:33 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Well, Poorboy and Mike P have been there and done it, so I defer to their 1st hand experience.
The 54 (55?) I did wasn't as serious on the inner fenders!
Re: flathead 6 removal [Re: zrxkawboy] #1853383
06/20/15 08:17 PM
06/20/15 08:17 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Mark your wires as to where they connect, there's not that many but it always helps, take pictures if you can, bag the bolts/nuts and label , motor mounts, bell housing, manifold etc. It might seem a little much to do but if your not putting it back together tomorrow you'll appreciate the extra effort knowing where things went.
Re: flathead 6 removal [Re: zrxkawboy] #1853960
06/21/15 08:35 PM
06/21/15 08:35 PM
SD
Z
Z
SD
Much thanks for all the input! BTW, I do have a FSM, but I don't see any instructions for engine removal. Maybe I need to dig deeper.
Re: flathead 6 removal [Re: zrxkawboy] #1854355
06/22/15 02:53 PM
06/22/15 02:53 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Most of the factory service manuals from the 40s & 50s make the assumption the mechanic is capable of pulling a motor out of the car without instructions. Times were much more simple then, and the process had not changed much. It is not like cars of today where specific processes need to be followed or you can't get it out.
Unfortunately, if you have only pulled motors out of new stuff, the way they did things back then are a bit strange.
My son's 57 Dodge wagon had a V8 with an auto. Because someone had already removed the front inner fenders before we got the car, we are not sure what was done, but we are in the process of re-installing those inner fenders, and there are a lot of bolts. The inner fenders are bolted to the fenders, to the radiator support, the firewall and have a coupler brackets attached to the frame!
We did remove the front bumper (Dodge is different then a Plymouth, at least, in appearance) and there were 8 bolts (on each side) attaching the bumper to the frame. At least 4 of those bolts (on each side) are only accessible with end wrenches and the proper combination of sockets & extensions. Fortunately, our car is a CA edition and the bolts actually un-wrenched. We have a MO parts car here, I suspect a guy would have to cut those bolts off, and that would not be fun (and this is at a welding shop). I can't imagine what a northern IL car would look like! Stuff would probably need to be cut to make clearance to cut the bolts. If you need to remove that front bumper, start loading the bolts with penetrating oil now. Once the bumper is removed, there are 2 bolts that hold the fender to the top of the firewall, two bolts at the bottom of the fenders to the cowl, and one large bolt in the center and the front sheet metal lifts off.
The V8 car has some strange motor mounts. We ended up unbolting them from the motor and from the frame, as we lifted the motor, we took them out of the way.
There are several bolts (6 per side, I think) that hold the transmission crossmember onto the frame. and 3 (I believe) that attach the transmission mount to the crossmember.
There are 2 wires to the starter (remove the starter because it will be in the way to pull the motor/trans).
The throttle linkage is mechanical and you will want to pull the rod between the carb (or the manifold pivot bracket) & the pivot bracket on the firewall off.
The heater core (on the Dodge anyway) extends 6" or more out into the engine compartment above the back of the motor. It is attached with several screws (10 or 12) around the outside edge, plus the heater hoses, plus the blower vent tube. That heater core removal will free up a lot of space above the motor.
There is a ground wire attached to the back of the motor that attaches to the firewall and wires for the coil & generator that need to be removed. The oil pressure is mechanical and has a tube attaching it to the gauge, and the temp gauge is also mechanical and has a fitting that needs to be disconnected. Of course you will want to remove the rad & rad hoses. There is a heater hose from the back of the motor to a heat control valve on the firewall that will need to be disconnected. Disconnect the exhaust pipe at the manifold and if there is a bracket on the side near the trans, it will need to be disconnected too. Don't forget to remove the driveshaft, transmission linkage, e brake linkage, and speedometer connection. I've probably missed something.
Since the front sheet metal was pulled off our car, we only had to lift the motor a few inches, and we did not have to remove the trans crossmember.
You will need to remove the crossmember,(a floor jack will be helpful) and your motor & trans will be standing almost straight up and down as it comes up to come out. You will have to tilt the motor enough for the bottom belt pulley to clear the radiator support while the trans will still be in the trans tunnel, then pull the motor/trans forward and raise until the trans clears the tunnel. Then everything needs to move forward and be lifted up until the motor/trans clear the radiator support and clears the front end of the car. Slow movement, watchful eyes looking for things hanging up, and a pry bar are useful things to have then. Be careful not you use your hands to "protect" hard car parts, those parts are tougher then your hands, and easier to replace. Once clear, you may be able to turn the motor/trans sideways to clear the car in a little shorter distance. There is also the possibility, that instead of moving the motor & trans while its hanging on the engine hoist, the car may be carefully (and slowly) pulled rearward.
I am sure I missed something in the process, but this should be close. Personal safety needs to be a high priority. Even though I pulled hundreds of motors, impulse still wants me to put a personal body part between two metal objects to protect something. You need to keep yourself aware of where your putting your hands & arms, as well as where helpers may be putting their hands and arms. In my shop the rules are: If it starts to go bad, get out of the way and watch it crash! We can fix whatever metal stuff gets damaged.
Good luck,
Gene
Re: flathead 6 removal [Re: zrxkawboy] #1854501
06/22/15 06:03 PM
06/22/15 06:03 PM
AZ
Mike P Offline
Mike P  Offline
AZ
I did a quick look at my manual and it doesn't give detailed instructions for engine removal and installation I stand corrected and Poorboy and zrxkawboy are right.
".....Most of the factory service manuals from the 40s & 50s make the assumption the mechanic is capable of pulling a motor out of the car without instructions....."
Another part of the explanation is that back when these cars were new when it came time to freshen the engine it was most often done with an "in car" overhaul. Basically the engine striped and the block and crankshaft were left in place. Valves were often just lapped and if they needed ground in the case of the flatheads, the valve grinder was a simple (and portable) hand grinder. There was even an "in car" crankshaft grinder if the crank needed redone.
The Plymouth bumper is not quite as complicated as the Dodge bumper (which for all intents and purposes are really 3 bumpers), but on the Plymouth there are brackets and bumper bolts on the very ends that are a real pain).
As far as the motor and transmission mounts the 6 cyl ones are a bit simpler than the V8 can mounts and can be left bolted to the engine and transmission respectively. The emergency brake cable and shift cable (if it's an automatic) will also need to be disconnected (that is covered in the shop manual). I would also recommend removing the engine fan for a couple more inches of clearance.
Personally I like the method of removing the engine that Gene describes which is as the engine is lifted moving the car back out under the engine rather than trying to move the cherry picker back (which usually sets the engine swinging). The engine leveler allows the steep angle needed to initially clear the radiator support and as the engine comes out it can be brought level again once the transmission clears the tunnel.
Finally one thing you may or may not be aware of ……whether you have a stick or an automatic you will find that the flywheel/torque convertor is NOT held on with crankshaft bolts. They both use studs pressed into the flywheel/convertor that pass thru holes in the crankshaft flange and are retained with nuts on the engine side of the crank flange. In the case of the automatic this can be a real PIA to line up and get started when you leave the transmission in the car and are installing just the engine.
Re: flathead 6 removal [Re: Mike P] #1854740
06/22/15 09:49 PM
06/22/15 09:49 PM
moparx Online content
moparx  Online Content
and just for the record, those that haven't done several[or more] of these jobs WILL learn "NEW" words and phrases. grin as stated above, be very careful to not hurt your self. years from now it might be a funny story to tell how your 2 fingers "disappeared", but it ain't gonna be so funny when it happens ![my one buddy knows from experience !]
beer
Re: flathead 6 removal [Re: zrxkawboy] #1854926
06/23/15 01:36 AM
06/23/15 01:36 AM
SD
Z
Z
SD
I appreciate all the helpful advice! I have one question: a guy on another forum (who also owns a 57 Plymouth) suggested unbolting the bellhousing from the trans, leaving the trans itself in place. I suppose this would require less "tilting" when pulling the engine. What do you guys think?
