I was putting my crossram together and noticed everyone else has a right angle fitting coming out of the carbs. My new carbs are fitted with a straight fitting. When I tried to track down a right angle fitting I had no luck. It is a 3/8 inverted flare on one side and 9/16 by 24 on the other. The only thread in common with this is on a compression fitting, however a compression fitting does not have a gasket surface to except the small sealing gasket. Do most people tap the bowls for pipe thread so they can find a fitting or is the right angle fitting no longer available?? I would like to find a fitting to avoid bending a right angle in my fuel line. Any help??? Thanks!!
